01 5.4 2v cats?
Old May 24, 2020 | 09:03 PM
Amanda Watts's Avatar
Amanda Watts
01 5.4 2v cats?
I am trying to figure out if my cats are clogged or is my fuel pump bad or bad regulator. Getting code p0141 tested fuel pressure 30 psi @ idle. But goes to 0 immediately. Also have loss of power and rough idle
Old May 27, 2020 | 07:26 PM
LxMan1's Avatar
LxMan1
A local exhaust shop will usually do a free backpressure test to check the cats. They drill a small hole in the pipe and use a pressure gauge, them weld up the hole after the test. The P0141 is usually a bad O2 sensor internal heater. When you say the pressure drops to zero, do you mean as soon as the pump stops?
carey965
2004 - 2008 F150
18
May 13, 2013 08:51 PM
sdtroubles
Mar 11, 2011 12:48 PM
TCamper
Modular V8 (4.6L, 5.4L)
Sep 28, 2008 03:20 PM
F-SUPER DUTY
Mar 15, 2008 07:29 AM
muscletruck7379
Dec 5, 2004 11:27 PM
