Sponsored by: Real Truck
Help Diagnosing
Old May 24, 2020 | 12:12 PM
Baun Jordan's Avatar
Baun Jordan
Help Diagnosing
Hey FTE,
Just picked up a 2001 F-350 7.3 powerstroke. I've had it for a about a month now, and noticed a grinding noise coming from the front end when I crank it all the way to the left and apply the brakes. I am thinking it's wheel bearings, but not certain. What do you all think?
Old May 24, 2020 | 08:18 PM
Djosbun's Avatar
Djosbun
Sure, it could be the wheel bearings. Jack up the truck, take the wheel off and turn the hub by hand.
You might also want to inspect the tire for any rub marks. If the tires are oversized and/or aftermarket wheels with incorrect offset, they might be rubbing when you cut the wheel all the way. Check both tires, too.
If the wheel bearing is bad, replace both sides.
-- Dave
Jon Unsworth
Dec 14, 2022 06:15 PM
Skyrobotv
Sep 4, 2016 06:30 AM
bradbow
Nov 17, 2010 06:28 PM
skeith5
Sep 30, 2010 05:18 AM
Bigredfan
Nebraska Chapter
17
Nov 21, 2008 06:30 PM
