Sponsored by: Auxito
Swap questions
Old May 22, 2020 | 01:44 PM
TaterNuts's Avatar
TaterNuts
Swap questions
02 F150. 16" cyclone wheels. Bought a running 97 for parts. Both 16" wheels, but my 21MM impact was too big on the older one. I checked and the threads are different. Can I still use these rims?
Old May 31, 2020 | 11:27 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Measure the lug holes' diameter at the small side and the big side, as well as the spacing between bolt holes. If they're the same then you should be good. Maybe if you want, post a picture of one of each type of lug nut sitting on a ruler for us to look at.
Old Jun 1, 2020 | 09:19 AM
ncranchero's Avatar
ncranchero
The '02 runs 14mm studs, the '97 runs 12mm studs. If the ''97's wont go over the '02 studs simply run a 9/16 drill bit through the holes.
Bessie
Feb 21, 2009 12:59 AM
ken's 80
New Jersey Chapter
Dec 7, 2008 01:36 PM
android
Feb 22, 2001 07:42 PM
