Enable Auto-Regen Checkbox
Old May 19, 2020 | 07:58 PM
DL222's Avatar
DL222
What is the best way to use this?
Most of my driving is long trips (not a every day driver). Before I add the check box I was doing a regen about the normal 500 mile mark. With the DPF% in the 60-70 range. My main question is should I let the regen happen around the 500 miles regardless of the DPF% or wait until full? What is better for the truck and filter? I'm not really interested in doing the "Operator Command Regenration" I would rather do it while driving.
Old May 19, 2020 | 09:12 PM
TeddyD's Avatar
TeddyD
I’ve played around with a lot of different ways of doing the regen. Now, I just let the truck do it’s thing and forget about it. If and when I am in a bind, I do and OCR.
Old May 20, 2020 | 05:45 AM
cpobst's Avatar
cpobst
I leave mine unchecked and force an OCR when it hits 100%. I've found it stays clean much longer doing an OCR vs letting it do it on its own while driving. This equates to less regens.
Old May 20, 2020 | 06:37 AM
Havok72's Avatar
Havok72
Does the truck run any different performance wise with it unchecked vs checked?
Old May 20, 2020 | 06:57 AM
cpobst's Avatar
cpobst
No, it just will not auto regen. You can watch your DPF% and when it gets full it will tell you then give you the option to initiate a static regen.
Old May 20, 2020 | 07:09 AM
BocaIvan's Avatar
BocaIvan
If you leave it unchecked and DPF gets to 97% and you decide to take it on a long run, will simply checking the box force the regen to start, assuming the conditions are right for a regen to occur?
Old May 20, 2020 | 07:55 AM
jbjones85's Avatar
jbjones85
Sure will (once it hits "FULL" and other conditions are met). I typically leave mine off as I do quite a bit of "city" driving and it always seems to be that a regen starts at the most inconvenient times. When I get the "full" message I take a 30-minute ride down the highway.
Old May 20, 2020 | 08:44 AM
BocaIvan's Avatar
BocaIvan
THanks JB, I may end up trying this out.
Like you, I tend to start regens at the worse times possible.
Old May 20, 2020 | 08:55 AM
jbjones85's Avatar
jbjones85
I just wish there was a way to force a re-gen when you know you're going to be on the highway for 15-20 minutes. I'm sure we are not the norm of Ford's owners here on this forum but would still be nice
Old May 20, 2020 | 11:31 AM
DL222's Avatar
DL222
Today I was at about 840 miles from my last regen when the clean filter soon popped up. I put the check in the box and the regen started up. Lasted about 15 minutes and all was good.
Old May 20, 2020 | 12:22 PM
F TOO FITTY's Avatar
F TOO FITTY
I did exactly this, and found that it will start the regen, but its never been an "instant on" thing with my truck. For example, the last time I saw the % said FULL, I checked the Auto-Regen box and it started maybe 20 miles later. I would have liked it to have started earlier, but it did its thing. Then again, I only know that its started when I notice the % dropping - it could have started a few minutes before that. Anyway...
Old May 20, 2020 | 01:46 PM
BocaIvan's Avatar
BocaIvan
Thanks for that info. Reminds me of how it happens now for me. I go by my odometer reading and I start watching the MPGs, and sure enough, regens start when I am halfway through my ride home and still going once I get here. So I know I am not "finishing" a regen.
When I notice this happening, I'll normally take a trip that weekend, about an hour and a half round trip, in hopes that I get a full regen completed.
I know we are not suppose to think about it and just let the truck do its thing, but having smaller increments between regens is not desirable.
Old May 22, 2020 | 08:53 AM
Mark250's Avatar
Mark250
I find it handy to postpone a regen if I'm nearing my destination and don't want a regen to start and end up being incomplete. The strategy is very strange though. Once enabled even when the truck is warmed up fully it does take a while to start.
Old May 22, 2020 | 12:06 PM
jollyrogr's Avatar
jollyrogr
What does the truck do if you get home while it's doing a regen? Does it finish the regen the next time you drive? Or does it wait until the DPF gets full again before starting another auto regen?
Old May 22, 2020 | 02:57 PM
cpobst's Avatar
cpobst
It waits until it's full again.
