Poor man's shower head fix
Then I noticed it didn't have quite the power it should on the highway and would stumble just a hair at times.
This all pointed to a fuel supply issue, not an air intrusion issue..my first thought was maybe a pin hole in the sending unit, although rare I have seen it before, so I wanted to drop the tanks. Being that one is full and the other was around half I said the hell with it. The bed is all beat up and I have other plans for a bed so I cut access holes with my cordless DeWalt..
Now I know alot of people dislike this method, but I will be welding in a hinge and tabs to make proper covers so they're just not open and since I'll be going back in there to replace the sender boards and probably the shower heads it'll save me some pain.
I wanted to share this method to get you by if it's a daily driver, or just save the $30 all together if it's a farm/whatever truck.
Now, it's a we'll know fix that people extend the unit with a piece of 3/8"s hose like this
This is fine and all, but there is a problem here, pieces of the old showerhead if you don't clean the tank, or pieces of anything can get inside the unit and do this
This happen to me before after I extended my unit with just a piece of hose, this time it happened just without a showerhead period..
My solution uses something anyone probably has around, aluminum window screen, get you a piece about this big and an extra hose clamp.
Now make it form to a bowl like shape around the bottom of the hose and fasten it back to the line with the extra clamp, be sure not to over tighten the clamp as it will smoosh the line, if you get a big enough piece you could extend it all the way back to the metal tube and clamp to the whole thing if you wanted to.
It's nothing pretty but it'll get ya goin and keep ya goin until you can replace your whole unit or showerhead.
I'm going to order some gasser sending unit float assemblies and see how well they fit, if nothing else I can use just the circuit board and solder it over. Will probably install new showerheads as well at that time. But until then I'll be rolling and keeping all that junk out of my fuel lines. I got really lucky that if anything did get further in the system it must have made it through the filter because it purrs like a kitten now and didn't even catch air on the first start up! This is exactly why our filter heads have a bypass to the return side, so any abnormal air can be purged without having to touch anything or bleed it.
I believe the mechanical was pulling a vacuum on the supply side and that after shutoff it would suck the fuel back to the obstruction. Thankfully this was a rather simple fix thanks to my cordless angle grinder, best $120 I ever spent, that and the sawzall to go with it.
Bonus pics of the bed
If it were up to me every truck made would have removable access plates just like most cars do to access the fuel pumps....
I put a 4" x 4" access hole in the floor of my van to access the middle tank sender. Then I made a custom bent sheet metal plate with weather stripping foam to seal it up. It's just nice peace of mind to know I can access it without the hassle of dropping the tank, especially since my biofuel system blocks the tank mounting hardware. I'd have to remove a lot of stuff to drop the middle tank.
Personally on the trucks I've had hell getting the bed bolts loose, I almost always have to torch them out..
I'd love to see a pic of your access plates, maybe it'll give me an idea of something more proper if I end up sticking with a truck bed.
I had a rock get between my skid and front tank once before. Ran a self tapper in the hole, scratched the metal around it with 40 grit paper, and jb welded over the whole thing.
I ended up getting someone to start the bolts for me as that front skid is pretty long/awkward
If you're bullnose, the front unit is removable with the tank and bed in, bricknose is probably the same but there is a driveshaft shield in the way. It's tight but doable on my 85
Tank is light when it's empty.
I guess over time it would probably revert back into oil.
