What would it take to put a 300 straight six in the place of a 352 and would it bolt directly to my 4spd and what years of motors will work and what do I need to put it in my truck is a 66 ford f100 with a 352 and a 4spd
I'm thinking the motor mounts are not the same... As I recall, the 300 has the same bell housing pattern as a small block. I installed a 300 in the place of a 302 in a dentside years ago. Finding the correct motor mounts was the hardest part as I recall. Good luck. I'd considered this same swap in place of my y-block, but my block checked out so I'm keeping it original. If you do go forward, I'd look for a mid 90s fuel injected unit. Swap over all the wiring and you could also use the trans (if the donor still had it).
The frame mounts can be used if they are moved to other frame holes which should be there. You'll need a different bell, but your 4spd should work with it.
Eric
I'm not too familiar with mounts but the parts suppliers suggest that the 65-74 240/300 mounts are the same. The bell housing and it's contents would need to be changed. The bell is the same as the 302. There is more than one "4spd" found in these trucks which one do you have?
im not sure on transmission just a factory 4spd so would I need a bell housing from a 302 and what years would work and will I need the clutch from the 302 also thanks
Just a couple comments...
- I think the 302's are internally balanced (I'm not sure) but I'm positive the 300 I-6's are externally balanced so you'll need a flywheel for a 300.
- Also, since you'll definitely need a bellhousing anyway, now is the time to consider getting a 5 speed with integral bellhousing. You may need to monkey with the driveshaft but if you do any amount of highway driving you may like having a 5 speed...kinda depends on how you want to use the truck.
a 5spd would be nice but I’m clueless on what 5spd to use and what would be a good 5spd with a 300 straight
If the 300 has the same bell housing as the small blocks, 302 in particular, a T-5 out of a fox body mustang would work. Maybe swap the back half of it with an S-10 T5 to get the shifter more forward.
No, you don't need a bellhousing from a 302, the bellhousing just happens to be for both. You do however NEED a clutch kit for a 300. Commonly available over the counter.
FYI, 302s are externally balanced... Early motors used a 28 oz. weight and newer motors used a 50 oz. When upgrading to a 5 speed, you must use the correct flywheel and balancer for the trans. A t-5, being originally used on the later 302s, should require a 50 oz. flywheel. Then there are 2 different tooth counts as I recall. 157 and 164, IIRC. I believe the same goes for the 300. It's been a while since I've done the t-5 swap into my Mustang, but it was pretty straight forward. I see several guys around here have done the swap, which surprises me... The t-5 is a decent car trans, but not great for a truck. Kind of light duty and the gearing is not really meant for a heavy truck. I could see blowing one up if One were to tow often with it. My 2cents.
Please correct me if I'm wrong 300, 302 & 351w all the same bell housing to engine mounting pattern. In previous threads I haven't seen it mentioned where a ZF5-42 is a good option for the 300 in these old trucks how does the ZF5-42 and the M5OD-R2 compare? Would this be a good option for Branden as well?
The flywheel has absolutely nothing to do with the transmission. The flywheel balance is strictly to balance the ENGINE. He is trying to use a 300-6, he just needs the correct flywheel for the 300-6, and the clutch parts to match the 6 with the correct spline for whatever trans he uses. He will also need to make sure the front shaft in the trans is the same length, and spline for the bell housing and clutch.
