Wtf is this
Old May 11, 2020 | 08:45 PM
Fordshmord's Avatar
Fordshmord
Wtf is this
Hole in the transmission with this thing in it?
Old May 11, 2020 | 08:55 PM
Fordshmord's Avatar
Fordshmord
Can
can transmission fluid leak out of this hole? What is that thing?
Old May 11, 2020 | 11:17 PM
892504x4's Avatar
892504x4
What year, model, engine and transmission?
My guess is the hydraulic line for the clutch and the hole has been busted out more.
And you need to connect the plug for your backup lights.
Old May 11, 2020 | 11:35 PM
85e150's Avatar
85e150
Looks like a Mazda CORRECTION--ZF 5 speed with the hydraulic line going in to the throw out. As above, busted hole.
If it could leak, it would be. That is in to the bell housing, or clutch housing part of the transmission.
Old May 12, 2020 | 01:00 PM
Freightrain's Avatar
Freightrain
Ditto. Nothing wrong, looks like someone got a bit zealous with replacing the line? Or pulling transmission and broke the casting. Nothing there to leak. No worries.
Old May 12, 2020 | 01:47 PM
Fordshmord's Avatar
Fordshmord
94 died f250 5.8. is that what that red connecter is the backup lights?
Old May 12, 2020 | 01:48 PM
Fordshmord's Avatar
Fordshmord
Thanks man I was worries about it
Old May 12, 2020 | 01:53 PM
Fordshmord's Avatar
Fordshmord
Originally Posted by 85e150
Looks like a Mazda CORRECTION: ZF 5 speed with the hydraulic line going in to the throw out. As above, busted hole.
Its the stock 5 speed, says does on the side of it. I didn't realize it was the line for the clutch tho thanks bro
Old May 12, 2020 | 04:32 PM
85e150's Avatar
85e150
Correction: ZF has the diagonal ribs, Mazda are vertical/horizontal. An F250 would almost always have the ZF, iirc very few had the Mazda but I can't recall the particulars. Light Duty?
Anyway, OP has a ZF.
Old May 12, 2020 | 08:06 PM
892504x4's Avatar
892504x4
Yep, the loose wire plug connects there.
Old May 17, 2020 | 04:22 PM
Fordshmord's Avatar
Fordshmord
​​​​​​Bet, thanks
Rembrant
Apr 13, 2019 08:43 PM
learpilot
30
May 2, 2009 05:07 PM
Hotwheelbill
15
Mar 29, 2006 03:55 PM
tlb
Mar 7, 2004 03:30 PM
