Transit Connect 2010+ Ford Transit Connect
Cargo Net
Old May 11, 2020 | 12:28 PM
Charles Hopkins's Avatar
Charles Hopkins
Cargo Net
Does anyone with a Transit Connect have the rear cargo net, part no. VET1Z-17550A66-A? Before I buy one I would like to know how you install the upper mounting points. My TC has the lower points but not the upper ones. I assume they get drilled in / screwed in. Is there a template or markings in the instructions to show the correct place to put them.
Old Sep 10, 2020 | 06:50 AM
dacflyer's Avatar
dacflyer
I think i have the cargo net that you speak of.. mounts right behind the front seats ?
there is a ridge on the roof, right above the seats.. you will have to drill holes and use the ribnuts they supply..
i changed out the one i had after i got my van,, i put in the hard wire cage..
Old Sep 23, 2020 | 12:15 PM
Charles Hopkins
No, this one mounts way in the back. It basically is used to capture things that might fall out the rear door or liftgate when you open it.
Old Sep 23, 2020 | 01:59 PM
dacflyer's Avatar
dacflyer
oh, ok,, I just looked up the number you provided.. Is this it ? >>------> https://www.levittownfordparts.com/s...7550a66-a.html
I think you will still have to drill and use rib-nuts. But looking at this kit, it says no tools required, Hmmmm
My van is the full cargo XLT, no passenger seats in the back.
My van also had I think aftermarket side walls as well..But i have had to remove them to do some upgrades.
There is a lot of metal behind the walls, but also a lot of holes. and you will need to watch out for wire harness.
I'm surprised that there are no instructions anywhere...just sellers.
geoffthepilot
Mar 1, 2016 06:23 PM
gtmustang00
Nov 23, 2011 04:01 PM
1955effie
Oct 15, 2006 03:55 PM
