2020 F-350 bed camera issues
I am also having issues, and sometimes it seems to affect other cameras as well. Have all of you guys made changes in the truck using ForScan, one of the things that has been discussed is whether the DPF% screen is affecting it (I had it enabled, then turned it back off, still having an issue) or the actual temp readings above the gauges. Just trying to figure out if there is a systematic cause. Also, do you guys have the 5th wheel prep package, so the in bed connector, and do you have the trailer camera TPMS option, and have you wired it all up and are using it? I have both, and have wired up my conventional bumper pull trailer with the camera and the TPMS sensors, but the trailer camera always seems to work fine.
I have the 2020 F-250 and my camera went out. The dealer replaced the camera and it fixed that problem. Then I noticed the the center line was missing and had to take it back to the dealership. The tech said it was not suppose to have a center line. I had to show the service advisor on a new truck on the lot so he could prove to the tech it did. That gave me a warm fuzzy feeling. After a couple of hours they finally figured it out and all works as it is suppose to.
Do you use Apple CarPlay - I can replicate the camera issues after activating CarPlay - if I try to view the 3rd brake light camera with Apple CarPlay active - it corrupts the camera image and sometimes all the other camera images as well until I power cycle the truck and not use Apple CarPlay.
Mine did the same thing when i first brought it home. It would be grainy, like it was getting interference, and then the screen went blue. I took the 3rd brake light off, removed both connections (light and camera), and reconnected them. After that, it’s worked just fine. One of the connection might not have been fully seated.
