Small Ring ID
Old May 9, 2020 | 12:07 AM
lp31's Avatar
lp31
Small Ring ID
I'm rebuilding a stock 351W. I found this piece in the oil pan. It looks like a ring that broke off. I'd like help to identify this.
Old May 9, 2020 | 04:27 PM
85e150's Avatar
85e150
Wrist pin retainer?
Old May 9, 2020 | 06:15 PM
f5fordgirl's Avatar
f5fordgirl
Not all engines used pin keepers, but if it was, there should be a bad place in the cyl. might be something that was dropped in the last time the engine was worked on.
Old May 9, 2020 | 06:30 PM
85e150's Avatar
85e150
If it came out, it would be in pieces after chewing up the cylinder wall and piston as you note.
Hard to imagine how it could end up in the pan via careless dropping. When you install pistons, the pan is off. Maybe dropped and "hiding" somewhere during assembly.
Another mystery perhaps.
Old May 9, 2020 | 09:44 PM
lp31's Avatar
lp31
Might be too small for the keeper from the looks of it. Besides, there doesn't seem to be any damage whatsover to the cylinders.
Could it be some sort of retainer from the oil pump drive shaft? It's roughly that size, maybe slightly larger.
Old May 9, 2020 | 10:52 PM
85e150's Avatar
85e150
I think that's a bingo. Makes sense.
Old May 19, 2020 | 06:00 PM
baddad457's Avatar
baddad457
Small block Fords had pressed in piston pins. Only the FE series had floating pins with retainers and that's not one of those
Old Jun 9, 2020 | 09:17 AM
5851a's Avatar
5851a
Piece of fuel pump arm return spring?
Old Jun 9, 2020 | 09:34 AM
baddad457's Avatar
baddad457
Could be. Or the oil pump relief spring
Old Jun 9, 2020 | 10:42 AM
lp31's Avatar
lp31
This is likely what it's from. I did change the fuel pump at some point last year. I can't see it missing from anywhere else. Thanks for the help!
calvinhg
6.7L Power Stroke Diesel
Aug 8, 2024 07:04 AM
runawayhound
Jan 13, 2019 05:18 PM
49fordv8f4
Mar 29, 2018 06:02 PM
sengel1975
Jul 25, 2015 08:08 AM
Crewcab Turbo
18
Jun 21, 2013 01:21 PM
