Will rims that fit a 2000 F350 fit a 2020 F350? I just ordered a 2020 F350 and have fairly new tires and rims on my 2000 that I would like to swap to it. Thanks.
What are the specs on the wheels from the 2000? The bolt circle should be the same, assuming SRW, at 8x170 for both years. But I think the 2020 needs a minimum 17" wheel to clear the brakes.
If the trucks are duallys, then you are out of luck. The 2020 dually bolt circle is larger (8x200) than the 2000 dually (8x170.)
The new f350s may all have the Dana instead of sterling.. I never would have thought of this being an issue for wheel fitment but the depth of the center caps seems to differ
Thanks for the response! Here are the specs on the rims. Not a dually.
They should fit, the rear hub caps may not though. And the balancing weights will need to be in just the right spot to avoid rubbing the caliper with 17" wheels.
