Sponsored by: Auxito
CV joints bad? Pics
Old May 7, 2020 | 02:34 PM
turborich's Avatar
turborich
CV joints bad? Pics
I was looking under the truck and to me it looks as if the drivers CV joints may be broken or something not right due the the angle? Thoughts? Compare passengers side with drivers.
Thanks.
Passengers
Drivers
Old May 7, 2020 | 02:37 PM
turborich's Avatar
turborich
Passengers
Drivers
Old May 10, 2020 | 12:36 PM
honda250xtitan's Avatar
honda250xtitan
is the boot torn? angle looks a bit more severe on the one side. does the truck sit level from passenger to driver side?
Old May 14, 2020 | 08:59 PM
turborich's Avatar
turborich
Yep, truck sits level, however like you stated, the drivers side CV axle shaft it definitely at a more angle vs the passengers side. The boot is torn, but not all the way around and I believe this is from rubbing on the shock.
Old May 15, 2020 | 02:02 AM
honda250xtitan
lift height shouldn't matter with shock clearance. it probably tore due to the angle it's at and the fact that it's always spinning. I wonder why one side has more angle? is the torsion bar cranked up on one side?
Old May 15, 2020 | 02:27 AM
turborich's Avatar
turborich
truck is completely level and everything looks good except for the angle of the shaft. I can't figure out what it could be unless it's the internals of the CV's themself? I jacked the truck up and spun the wheel, no weird noise and the shaft turned quietly though. I guess I'll just buy a new assembly for the drivers side and see if anything changes. It has a 6" fabtech lift and everything looks symmetrical except for the drivers axle shaft. Both sides have the axle spacers installed.
Old May 17, 2020 | 02:21 PM
honda250xtitan
thats wild. after installing the new one maybe tear apart the old one's boots and see if the cv has done something weird?
82_F100_300Six
Aug 26, 2019 09:09 PM
ExPACamper
21
Jul 27, 2017 06:48 PM
72CC428
15
May 14, 2016 01:34 AM
lilpro
All Things Towing
13
Mar 22, 2010 09:50 PM
DieselCamper01
Jun 6, 2009 11:08 PM
