speedo gear
Old May 7, 2020 | 12:48 PM
gypsyman's Avatar
gypsyman
speedo gear
I recently got a 69 f-350 manual 4 speed. the drive gear for the speedometer (inside the tranny) is missing. When I went to LMCtruck to see about ordering a replacement, they wanted to know "how many teeth" the choices were 16-21. so without having the old one to compare it to, how do I know which is the correct one for me?
Old May 7, 2020 | 03:54 PM
Tumbleweed1972's Avatar
Tumbleweed1972
There are websites online that will calculate it out for you. Because it is a manual speedometer you can change your gear to make adjustments for different tires or gear ratios. More than likely you've got a 7 tooth drive gear, this is the one that is in the back of the transmission.
https://www.tciauto.com/speedometer-gear-calculator
PetesPonies
Jun 2, 2010 11:04 PM
ken selvy
May 13, 2008 01:12 AM
MikeGV
Sep 26, 2005 09:30 PM
boogity24
Aug 10, 2004 08:10 PM
slifer
Sep 10, 2003 10:30 AM
