oil pressure sensor
Old Feb 5, 2001 | 09:25 AM
chefbill's Avatar
chefbill
oil pressure sensor
OK...How in the hell do you get the oil pressure sensor off???
it is really in a hard to get to position!!
95 F150 ext cab 4x4 swb orp with 351 at 164,800
Old Feb 5, 2001 | 09:41 AM
PAUL_2's Avatar
PAUL_2
oil pressure sensor
There is a socket designed to remove oil pressure sending units . You should be able to find one at most auto parts stores .
Old Feb 5, 2001 | 09:14 PM
desperado_18_2000's Avatar
desperado_18_2000
oil pressure sensor
depends on the motor, but if its a 302 it should be on the right side of the motor near where the fuel pump is *or should be, i'm goin old school here* or either near the oil filter, a 9/16 wrench should take it off.. or either a pair of pliers.. mine went bad too
1982 F-150 351C
1987 XLT Ranger 2.3L
Old Feb 6, 2001 | 10:57 AM
bgodkin's Avatar
bgodkin
oil pressure sensor
If you can get ahold of the body of it with Channel Locks you should be able to spin it right out. Putiing the new on in should be a little easier than coming out was. Using a ton of words that would make a sailor blush helps sometimes too. I learned that working on the wifes Grand am (Grand Damn). Hate that thing.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Feb 6, 2001 | 11:32 PM
toecutter's Avatar
toecutter
oil pressure sensor
