Rear end help
Old May 5, 2020 | 05:30 PM
Jason62371's Avatar
Jason62371
Rear end help
I have a 94 ford f 150 4x4 5.8 355 gears. When I let off the gas sometimes I have a clonk in the rear end.sometimes when I turn hard it growls a little. How hard would it be to replace the bearings? It’s not the joints just a FYI.
Old May 6, 2020 | 02:01 AM
Edward Michael's Avatar
Edward Michael
Not for sure at this rear end.....but the axels have to come out to replace rear bearings....
have to open the pumpkin and take out some clips of the axles to let them slide out.
check your yoke play and seal too. Replace the axle seals if they dont come in a bearing kit...
might as well do your brakes while yer there....
Old May 6, 2020 | 05:11 AM
Thejackalope's Avatar
Thejackalope
The bearings are pressed on. Also a clunk may indicate excessive play in the ring and pinion.
Old May 6, 2020 | 05:20 AM
matt167's Avatar
matt167
I had a '96 that had so much play in the pinion bearing it practically fell out. It still drove but it was a little rough.. Was lucky enough to grab another axle out of a '92
Old May 6, 2020 | 08:37 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That depends on your skill level. It sounds like it could be the pinion bearings. As mentioned, the carrier and (lower) pinion bearings are pressed on. Do you have torque wrenches to reassemble everything?
Old May 6, 2020 | 10:20 AM
Thejackalope
You will need a bearing puller and a press to replace the carrier bearings and a slide hammer to get the axle bearings out.
king.t.cameron
1997 - 2003 F150
Feb 17, 2014 11:11 PM
Bootzz711
Nov 20, 2011 11:17 AM
79CAMOFORD
Sep 24, 2011 01:32 PM
RedneckNinja28
Nov 17, 2005 07:23 PM
hernando
Feb 9, 2002 02:30 PM
