2007 4.2L PCV
Old May 5, 2020 | 02:17 PM
1saxman's Avatar
1saxman
2007 4.2L PCV
Does a 2007 F150 with 4.2L V6 have a PCV valve?
Old May 9, 2020 | 12:36 PM
DBGrif91's Avatar
DBGrif91
Yes. It’s in the right valve cover nearer to the rear side of the engine. I’m not sure what year they changed it over, but some are electrically heated and some are heated using coolant.
Old May 11, 2020 | 01:35 PM
1saxman's Avatar
1saxman
Thanks. I need to check/replace it because I'm getting a little oil film on the rocker covers and it might be from a build-up in crankcase pressure. It only has 30,000 on it and basically is still like new. I did have to replace the crummy Ford battery after only 13 years. Oil has been changed every 2000-3000 miles (yearly) and only Motorcraft 5W-20 and Motorcraft filter has been used.
Old May 12, 2020 | 10:38 PM
1saxman's Avatar
1saxman
Wait; 'heated' Positive Crankcase Ventilation valves?
Okay, if they are, I know why - to thaw the valve in cold weather so it can work. I ran into this problem on a Saturn VUE I had. It was in the body shop for minor repair, and it was a cold January. They would bring it into the shop, then drive it out. They must have done this a few times and moisture built up and froze in a hose that had a low spot the way it was routed. I picked up the car and drove it away without realizing this, and it blew an oil leak in the rear cam cover.
Old May 14, 2020 | 11:58 AM
DBGrif91's Avatar
DBGrif91
Yep - that’s basically it. I can’t recall all the details, but there’s 2 types of electrically heated valves - one that’s switch activated at or below 40*F and one that’s PCM controlled at or below 32*F.
I think the coolant heated ones were intended to keep the valve hot after shut down to allow moisture to drain out of the valve/hose - there’s a maze of 1/4” coolant lines running from the intake to the valve to a fitting on the throttle body and back to the intake.
Also, you can test PCV operation by checking for vacuum at the oil dipstick tube. At operating temp at idle, vacuum should be 0-2 in*Hg. Ideally it’s less than 1 because it should be maintaining a balance between crankcase pressure and engine vacuum. Higher than 2” indicates a valve that’s sticking too far open at idle or a plugged breather filter (if equipped).
No vacuum (or positive pressure which can be read with a dual gauge if you have one) indicates restrictions which could be a plugged/partially plugged valve or baffle inside the valve cover, or collapsing hose.
Old May 20, 2020 | 10:03 PM
1saxman's Avatar
1saxman
Good tips. I'll do that test. I don't have a gauge but I'm sure I can feel a slight vacuum which will tell me there is not positive pressure. Its really a very minor film of oil. Most likely I'll just wash the engine more often.
2002f150owner
1997 - 2003 F150
Apr 19, 2013 08:49 PM
khadma
3.8 & 4.2L V6
Oct 16, 2008 08:53 AM
gixxerlance
1997 - 2003 F150
May 22, 2006 04:39 PM
jas_ridge
1997 - 2003 F150
Aug 11, 2003 11:44 PM
