7.3 idi knocking sound
Old May 4, 2020 | 07:36 PM
Patrick Austin's Avatar
Patrick Austin
Hey I just replaced the head gaskets in my 7.3 idk and now it seems to almost have a knocking like sound (sounds like a diesel trying to lock up on starting fluid) but this knocking sound isn’t constant and it seems to go away if you stand on it...I was just wondering if a bent injector tip could be the problem...thanks
Old May 4, 2020 | 09:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Does it have an auto trans? I had a flexplate crack and it sounded like the engine was going to come apart. Same symptoms. Real bad at idle but quiets down under load. I looked up in at it and I could see the crack.
Old May 5, 2020 | 05:54 AM
Patrick Austin
No this truck has the zf5 in it
Old May 5, 2020 | 03:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
the dual mass flywheel could be bad too. i have seen them fall out of the truck in 6+ pieces, and they sounded like the engine was ready to grenade.
Old May 6, 2020 | 03:58 PM
Patrick Austin
But that won’t make it smoke tho right?
Old May 6, 2020 | 05:09 PM
tjc transport
i ain't rite
no, but you did not mention it smoking.
Old May 6, 2020 | 05:38 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you had the engine hydro locking on you... so when you pulled the heads did you send them to machine shop for NDI ?
did you inspect the Cylinders or have a machine shop inspect the cylinders ?
I know you said you just replaced the head gaskets, but did you discover if they were in fact leaking ?
Old May 6, 2020 | 07:58 PM
Patrick Austin
Yes I had the heads sent out and everything checked out ok and the head gasket was getting rotten and was leaking through...it ran pretty good on the first start after the head change so I shut it back off and changed the oil and topped off the antifreeze again and when I went to start it again it started acting goofy
and it just started smoking today it wasn’t before.
Old May 6, 2020 | 08:53 PM
FORDF250HDXLT
What color is the smoke?
Old May 7, 2020 | 05:32 AM
Patrick Austin
The smoke is blue and smells like fuel
Old May 7, 2020 | 03:54 PM
tjc transport
i ain't rite
stuck injector.
Old May 8, 2020 | 07:21 AM
Patrick Austin
I cracked all the injector lines and on every one the motor ran different so I couldn’t tell which one
Old May 8, 2020 | 10:15 AM
Olds64's Avatar
Olds64
I installed used injectors on my 6.9l NA from the 7.3l IDIT I bought about 2 years ago. When I had everything buttoned up I got ready to start it and had my buddy crank it while I bled the injectors BUT it had a horrible knock.
Luckily I never started the engine. I just went ahead and removed the injectors and got new ones from the parts store. Once I installed those there was no knock and it ran like a champ. As Tom said, one of those salvage injectors was apparently stuck.
Old May 8, 2020 | 12:25 PM
tjc transport
i ain't rite
yup. IDI injectors are strange ducks. they can look like they are brand new, and leak like an open faucet.
Old May 8, 2020 | 12:31 PM
Patrick Austin
alright I’ll look into switching the injectors thanks guys
