Trying to change starter
Old May 2, 2020 | 03:28 PM
donthekawguy's Avatar
donthekawguy
I have a 1972 460 in my 78 f250. I'm trying to change the starter but its stuck in the motor. Got the bolts out and it moves a little if I push up on it but it won't drop out. Just keep wiggling it, pry on it a little or smash it with a sledge? Feels like the teeth are too engaged for it to come out. Maybe I'll rotating the motor a little with a breaker on the crank? Any suggestions would be appreciated.
Old May 2, 2020 | 05:46 PM
donthekawguy
Old May 4, 2020 | 06:06 PM
donthekawguy
New problem with starter replacement
Finally got the old one out and now the new one just makes a clunk when I turn the key. Almost like it has a low battery. The battery is good, the starter checks out good, new solenoid, all connections cleaned, battery fully charged. I drove the truck into the garage changed the oil fired it up with the old starter. When I went to pull the old one I pulled the wrong bolt and pryed up on the old starter until the ear broke off. woops. Not sure what the problem is now. Any advice would help.
donthekawguy
BTW the motor is a 1972 460.
Old May 4, 2020 | 07:03 PM
85e150's Avatar
85e150
Thread from FE forum merged.
