Sponsored by: Real Truck
2011 AC issue. High head pressure.
Old May 2, 2020 | 03:27 PM
Fefanatic's Avatar
Fefanatic
OK, here goes. I have this 2011 with 6.7 and the air conditioner will not get cold. I put gauges on it and it immediately heads to high pressure (400+lbs) and cycles the compressor. So I thought the expansion valve is clogged or bad. I replaced the expansion valve and again immediately went to high head pressure. The compressor was noisy so I decided to clean/replace/flush the whole system. I removed and replaced the compressor with new Ford (not reman), replaced the condenser from Rock Auto (Motorcraft), removed and flushed and cleaned all ac hoses. I also ordered another expansion valve again Ford parts. The only thing I have not replaced is the evaporator and I flushed and back flushed it out.
Still after all that I have high head pressure. So again, I replaced the electronic fan assembly, it is turning while running and seems to be turning about the same amount as my '15 does when it's running with ac on.
I am at wits end, Anyone have any suggestions? I have a AC background and this one is baffling me. I've checked everything I can think of short of replacing evaporator. If there were a clog in the system then the low side would go extremely low when the high side maxes out. That's not happening.
While the high side keeps going up the low side stays within a fairly normal range, it might be just a tad high but nothing like what I see on the high side. I also use a ac scale to weigh the amount of freon entering the system so I know it's not overcharged.
Old May 5, 2020 | 05:41 PM
metalsmith's Avatar
metalsmith
The only thing left is the filter dryer.
Old May 5, 2020 | 06:33 PM
Fefanatic's Avatar
Fefanatic
The filter is installed in the condenser and was included with the new condenser. I know that because I did order a new filter and when I went to install it there was a filter there already.
Old May 5, 2020 | 07:09 PM
metalsmith's Avatar
metalsmith
I hear ya’. This one is a puzzler. Shed heat to drop pressure, but the fan is good and condenser clean.......
Old May 6, 2020 | 06:00 AM
projectSHO89's Avatar
projectSHO89
Does it go immediately to high pressure when the compressor engages? If so, it sounds like a restriction in the high pressure circuit.
Hit the condenser with the spray from a garden hose. Does the pressure drop? If so, there's insufficient heat rejection.
Gary E
1983 - 2012 Ranger & B-Series
May 15, 2014 09:12 PM
ramsay
Oct 13, 2012 12:13 PM
tshrager
May 2, 2012 07:48 PM
Merlin509
Jun 8, 2005 06:09 AM
Luzer27
Jun 1, 2005 11:04 AM
