Aerostar Ford Aerostar
a4ld transmission
Old Oct 16, 2003 | 04:30 PM
saiter's Avatar
saiter
Question a4ld transmission
will a a4ld transmission out of a 88 merkur scopio fit in a 1990 aerostar
Old Oct 16, 2003 | 08:08 PM
aerocolorado's Avatar
aerocolorado
It should. The A4LD case is the same for all models, just different internal components. If you will be using it behind a 3.0 engine, it should work. The 4.0 versions require stronger internals.
This also assumes you have an existing A4LD that will be the donor for the shifter, speedo cables, wiring, etc.
Old Oct 16, 2003 | 08:59 PM
saiter's Avatar
saiter
thanks for the reply yes im putting it in an aerostar that has a bad a4ld in it
Old Oct 17, 2003 | 02:05 AM
xlt4wd90's Avatar
xlt4wd90
Hi Aerocolorado,
Is the A4LD in an AWD vehicle the same? Mine looks like it has a very different tail housing, where the transfer case is attached, than one without.
eugene
Old Oct 17, 2003 | 09:50 AM
aerocolorado
Yes, the extension housing is absent on AWD version. They just leave it off and graft the transfer case in its place.
