Brake Cable Extensions
Old Apr 30, 2020 | 04:11 PM
corkinaz's Avatar
corkinaz
Hello,
I have a 1966 Ford F-100 4x4 long wheel base. Looking through some old threads it appears that the emergency brake cable set up for LWB trucks had 12-14 inch cable extensions that are now obsolete. I am trying to find a solution. Any suggestions would greatly be appreciated.
Old Apr 30, 2020 | 04:59 PM
53deere's Avatar
53deere
The 2wd trucks had the same extensions, I assume 14" because that is the difference in the wheelbase. I shortened my truck 14" to make it a short bed and everything hooked right up without the extensions. If you can't find any local from a 2wd I have the ones from my truck you can have for the cost of postage, I'd just have to find them.
Do you have any photos of your truck? '66 4x4 is my favorite truck.
Old Apr 30, 2020 | 06:55 PM
BobbyFord's Avatar
BobbyFord
Damn, I just threw some away last weekend.
Old May 4, 2020 | 05:04 PM
corkinaz's Avatar
corkinaz
Thank you 53deere. I made a handful of phone calls here locally and think I may have found some. Its a work in progress, but here is a picture of the truck.
Old May 4, 2020 | 06:17 PM
53deere's Avatar
53deere
The truck is looking great. Did you put the lift in it? How much lift over stock?
Old May 5, 2020 | 09:25 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Truck is looking very good. In that picture - and it might be an illusion - the front of the bed looks a touch low. If I hold a straight edge up to the bottom of the door and front fender and compare that to the bed I can see it is off in the picture, at least. 1/2" shims might be all it needs. You may have already corrected that, too.
Old May 5, 2020 | 01:06 PM
corkinaz's Avatar
corkinaz
Thank you 53deere and TA455HO
No lift, I have put on some different rims, tires, etc... since this picture was taken.
I put new cab mounts in and do need to put in some spacers in the bed. It is not as far off as the picture shows, but still needs a bit of alignment.
Old May 5, 2020 | 06:41 PM
53deere's Avatar
53deere
I guess it looks about the same height as this one...
toddelia
Apr 2, 2019 10:35 PM
POPAJON
Mar 12, 2016 01:31 PM
POPAJON
Mar 10, 2016 11:06 AM
sullyda1
May 24, 2005 01:45 PM
