Valuation help
-F250 HD
-4x4
-351w
-4 Speed Manual w/ Granny
-Dump Truck Suspension
-3 Inch Lift
-PTO
-3.90 Gears
-Dana 60 Front
-Dana 80 Rear
-Aluminum Transfer Case - Hi and Lo
-Pipeline Registration + Tags
-No Mechanical Issues - Daily Driver
-Frame is solid and has minimal surface rust
-Body is rusted
Could it be you meant 2 speed transfer case? high range & low range.
Also
How many miles on the truck?
Only the 1 picture is kind of hard but from what I am seeing of the door, over the wheel on the bed and many be the lower front fender, I bet there is not a lot left of the floors, cab corners and maybe more with out looking at it in person. Hoods where the hinges bolt like to rust out.
If I was looking to buy it and what I see of it I would not go over $1000 and even then maybe not that high.
Someone may pay more if they are looking for a truck like that and did not care the shape the body is in as they could fix it.
See what others have to say.
Good luck
Dave ----
The PTO was hooked up to a flatbed but am not sure what else it would run
86k miles
the truck comes with ID tags + other misc for the IPAA, I don't know if there's anything special about it
Frame is immaculate body is ruined just like you said
Last edited by T M0NEY T; Apr 28, 2020 at 05:55 PM. Reason: Forgot to type something
You could list it for $2k obo and see if you have any interest.
Be aware that selling a used car is a PITA right now with COVID 19 and social distancing. I've had my 71 Oldsmobile listed for 6 months on CL and recently had 2 or 3 interested people. Unfortunately, I wasn't able to meet with them.
