Dumb guy
Old Apr 27, 2020 | 01:49 PM
Bdale57's Avatar
Bdale57
Dumb guy
Ok the manual says the PCM is at the driver's kick panel when you read the fuel system chapter and then it says the PCM is under the instrument panel when you read the engine electrical chapter. Is the PCM the brain? Why two locations? I have a basket case '93 f150 4.9l. I've been to the junkyard and my truck is missing the box under the instrument panel. What is the box I'm missing. Thanks for any info to help an idiot.
Old Apr 28, 2020 | 10:22 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Apr 28, 2020 | 11:44 PM
Edward Michael's Avatar
Edward Michael
Hey,
Power Control Module or EEC is at driver’s kick panel by the emergency brake....its under the instrument panel.
thats what your truck is missing?
You have been to the junk yard and found the part?
do you have a picture?
Best Regards!-)
Old Apr 29, 2020 | 08:02 AM
65windsorcoupe's Avatar
65windsorcoupe
It is technically "behind the kick panel" BUT you actually take it out from the engine bay and it is easier if you partially remove the wheel splash shield to be able to slide it out. remove 10mm bolt for wiring harness, then two 10mm nuts holding the seal in place then slide out the computer. Just did this on a 1994.
Diddy12
Dec 25, 2019 09:07 PM
first today
37
Oct 28, 2009 07:35 PM
PepperandSpice
New Member Introductions
Feb 15, 2008 06:21 AM
Andysutt
Jan 5, 2004 07:57 AM
