95 302 to 90 351w swap
Okay guys I wasn't really sure where to post this so I started here. I have a 1995 f150 that originally came with a 302 and 4r70w trans. I ran into some trouble with the 302 a couple of years ago because of some bad oil (rubberized the entire inside of the block), so I swapped it with a 90's model 351w recently and used same wiring and computer from the 302. It's ran fine to this point besides having a trans that has 295,xxx miles on it and took a crap, gonna replace it and see what happens. Other than that are there any recommendations you guys have for doing this swap? It's an SD engine to maf computer swap is and Im wondering if I should have done more. Thanks in advance
