Need help wiring plow lights.
Old Oct 16, 2003 | 11:29 AM
tsheriff's Avatar
tsheriff
I need to know which wires on the back of the light switch are for the Hi/low beams. I am hooking up the lights on our snow plow and noone makes a harnes to put the low profile meyer lights on my 94. Everone tells me I have to use the New night saber lights. I took the lights off of my Dads 79 and they were wires into just ahead of the dimmer switch. This is how it was wired.
2 low beam wires into plow switch,
from plw switch back to 2 low beam lires
The the same for the high beam wires.
Was it wired this way to get full power from both lights? I can snp a few picks of the harness i have if it would help.
Old Oct 17, 2003 | 07:20 AM
BandBFord's Avatar
BandBFord
Cool
I have attached a link which may help also...I am looking in my manual for the wiring diagram... Below I will list the wire color, which switch it is at and where it goes...If my manual is correct maybe this will help...
http://www.cybrrpartspro.com/cgi-win...kupResults*****
Go to figure 30....
High/Low selector: wire color
Power in (fuse "A" engine compartment)... Dk Blu/Org
Power from light switch...............................Red/Yel
Power to low beams....................................Red/Blk
Power to high beams...................................Lt Grn/Blk
Main Switch:
Power in (Fuse "R" engine compartment)....Blk/Org
Power in (Interior fuse block #4).................Tan/Wht
Power out to Radio......................................Org/Blk
Power in (Interior fuse block #8).................Lt Grn/Yel
Power out to Courtesy lamps......................Blk/Pnk
Power out to High/Low Switch.....................Red/Yel
Power in from Ignition switch.......................Yel/Blk
Power in to light dimmer..............................Wht/Lt Blu
Power out to Marker lights..........................Brn
I hope this helps and I have tried to be as acurate as possible...
Old Oct 17, 2003 | 09:21 AM
tsheriff's Avatar
tsheriff
Thanks I'll see what i can figure out.
Old Oct 24, 2003 | 11:33 AM
tsheriff's Avatar
tsheriff
I fugured it out on sunday. I had to slice in right behind each headlight but they work. I hid all the wireing n loom and taped up anything that was visable. You cant even see most of it. THanks. The color of the wires were the same as the 79.
