Inertia switch
Old Apr 24, 2020 | 01:39 PM
Jfull1965's Avatar
Jfull1965
Inertia switch
Where would the inertia switch be on a 2018 E450, v-10 6.8 liter? I looked on the passenger side floor side panel oh, did not see it there. I've read somewhere where it might be behind the brake pedal but I cannot find it. Thank you in advance Jeff
Old Apr 24, 2020 | 07:36 PM
Franklin2's Avatar
Franklin2
It should be in the owners manual. You can download one here. https://www.fleet.ford.com/parts-ser...owner-manuals/
Old Apr 24, 2020 | 07:43 PM
Jfull1965's Avatar
Jfull1965
Thanks but it is not in the owner's manual.
Old Apr 24, 2020 | 07:57 PM
Franklin2's Avatar
Franklin2
It's in there under "roadside emergencies" section. Apparently it's some sort of automated thing, you have a keyswitch sequence to get it going again.
Old Apr 24, 2020 | 08:11 PM
Jfull1965's Avatar
Jfull1965
Ok. I'll look again.
I did a search for the word inertia which returned 0 hits
Thank you
Old Apr 24, 2020 | 08:16 PM
Jfull1965's Avatar
Jfull1965
Let me rephrase my topic..
I want to find the fuel inertia switch to splice a hidden toggle switch into the circuit either before or after the switch . This is my cheap anti theft on the truck
thank you
Old Apr 25, 2020 | 06:51 AM
tjc transport's Avatar
tjc transport
i ain't rite
that will not work because there is no "switch" to reset. it is computer controlled.
Old Apr 25, 2020 | 07:25 AM
Jfull1965's Avatar
Jfull1965
So just breaking the circuit with a switch will not work? If I was after the inertia and closed the switch, why wouldn't everything be back to normal? Am I correct in saying it appears this year's model doesn't have the reset style red button inertia switch.?
Old Apr 25, 2020 | 07:49 AM
Franklin2's Avatar
Franklin2
What about just pulling the fuel pump fuse if it's easy to get to? Or the fuel pump relay.
Old Apr 25, 2020 | 07:58 AM
Jfull1965's Avatar
Jfull1965
I've pulled fp fuse numerous times. My fear is wearing out the prongs on the fuse, plus I have to pop hood get to fuse, remove, hopefully not misplace it. A hidden switch would easier. This is in a class c motorhome on the 450 frame. Sometimes mh sits for long periods.
jeff
Old Apr 25, 2020 | 08:44 AM
tjc transport
i ain't rite
if that is the case put the switch in the fuel pump fuse line to take power away from the pump.
Old Apr 25, 2020 | 01:05 PM
Jfull1965's Avatar
Jfull1965
That was another of my ideas. Would you happen to know the color code on the wire that feeds the fuel pump?
thank you
Old Apr 25, 2020 | 02:00 PM
tjc transport
i ain't rite
no idea. i do not mess with vehicle security modules after an abandoned 12 volt power wire from a removed two way radio in my 2014 F250 shorted out and it cost me $1400 to repair.
Old Apr 25, 2020 | 03:18 PM
Franklin2's Avatar
Franklin2
I looked in this link, but can only find places to tap off to power stuff, not to cut anything off. I will leave this link in case you are interested. It's at the bottom of the document.
https://madocumentupload.marketingas...87d99&v5=False
Old Apr 25, 2020 | 03:20 PM
Franklin2's Avatar
Franklin2
Have you ever considered one of these disconnects of some type?
Amazon Amazon
