You want switched power to your console? Yeah, the upfitter stubs are under the hood. You can extend one to the pass thru wires and that’ll get you into the cab. That’s a convenient place to grab a ground too. From there you can tuck and zip-tie over to the console. Access is easy enough to drill a hole and have your wires emerge just about anywhere you want.
perfect, I was hoping I could find a wire under the hood but not that big of a deal. Thank you for your help
I have a rechargeable flashlight, don’t want it charging full time.
Just for a thought, I used an upfitter lead to power a fuse strip on the driver's side to power a few items I wanted on while driving. It works very well and easy to change when I want to add another device.
thats a good idea too, I will definitely be looking into that. Thank you!
