1978 - 1996 Big Bronco
Chasing Zebras
Old Apr 23, 2020 | 05:13 PM
FBronco1996's Avatar
FBronco1996
Chasing Zebras
I'm going to keep this as simple as possible, brief scenario:
Prior to this event, I had numerous codes, but they didn't prevent the Bronco from starting and running; just needed to be optimized.
( Crankcase sensor, O2 banks, Run Lean, Misfire, and others, to include an absent 12V to the rear end tailgate)
- Bronco was running fine, put gas in it and parked it overnight and come morning, no start ( Engine would crank and crank and crank, but it wouldn't turn over). Typically, I hear the rear fuel pump whine/prime when the ignition is ON......NOT this morning, no whine in the rear end.
Let the troubleshooting begin:
  • ALL FUSES ARE INTACT!
  • Kill switch to gas lines INTACT
  • Relays in PowerDist Box are INTACT, however, the Fuel Pump relay is not working properly. Replaced, still not working. I jumped the pins to see if I had power to rear end and I do! But only with the pin jumped.
  • OBD-II not linking; 12V present at cigarette lighter-works fine.
  • I did the old wire-in-hand trick to test for spark at the wires- No spark at spark wires.
  • Replaced ICM, still not working.
  • Replaced crank shaft sensor, still not working.
  • I did the old ether in the carb, still not working.
  • I was going to replace the fuel pump, but whats the sense with no power.
So, as I chase zebras, I realize that I am not the only one out there that has this problem.
Why is it that there are so many 96 Broncos having this problem?
Better yet, how do I fix it? I have read about replacing the distributor....one more zebra?
I read about a transmission switch in the column,....come on!
I have exhausted the internet and online forums trying to figure this problem out.
This process is not an efficient way to trouble shoot an issue; soon I'll be part poor!
Someone out there must know why this is happening and how to fix it.
F350AK
170
Feb 20, 2016 02:39 PM
drivewayford
1997 - 2003 F150
Apr 6, 2014 11:46 PM
RangerSaint
1983 - 2012 Ranger & B-Series
Feb 17, 2012 02:10 AM
montangrunt
21
May 13, 2004 03:15 PM
