No idle when cold
Old Oct 16, 2003 | 07:13 AM
bagby1954's Avatar
bagby1954
No idle when cold
On my 1999 Expedition with 5.4 motor, the engine will not idle when cold. I can keep it running by pressing the accelerator, but will not idle on its own until it is at temperature. No lights are on in the dash and the scanner shows no error codes. I would appreciate any suggestions. I have already replaced the air charge temp sensor.
Thanks
Old Oct 16, 2003 | 10:45 AM
PaulC's Avatar
PaulC
This is a very common problem. The Idle Air Control valve on the engine is either dirty or defective. As the name implies, this device regulates airflow into the engine during idle. Pressing the accelerator overrides this system, which is why the vehicle will idle and run while the pedal is pressed. Some individuals have had success cleaning this device, but replacement is a more permanent solution. You may wish to refer to the link below for more information.
http://www.ford-trucks.com/forums/sh...hreadid=160659
Old Oct 16, 2003 | 11:30 AM
bagby1954's Avatar
bagby1954
Thanks Paul. I hate these electrical problems!! On a side note, I am a newbie to this site but have used several others for other cars. This site is by far the best. Great info without all the wise cracks.
Thanks again.
Old Oct 16, 2003 | 03:57 PM
mahause's Avatar
mahause
That post should be a big help. I replaced my IACV last night in about thirty minutes. Thanks for the help guys.
Delkancott
Nov 22, 2014 12:01 AM
96gizmo
Jan 31, 2005 09:30 AM
Bristrew
Jan 12, 2005 08:18 PM
gregarious1
1997 - 2003 F150
Jan 9, 2005 02:44 PM
BroncoScott
Oct 23, 2002 11:47 AM
