Antenna Base Pad
Old Apr 19, 2020 | 12:45 PM
Otterby's Avatar
Otterby
Antenna Base Pad
Anyone know where can find the pad that goes between the antenna assembly and the body for a ‘59 F250?
Old Apr 19, 2020 | 06:53 PM
spurredon's Avatar
spurredon
I have seen them on Ebay in the past but get your wallet out. Junk yard best bet.
Old Apr 19, 2020 | 08:25 PM
JohnNewb's Avatar
JohnNewb
Can you cut one out of rubber gasket material?
Old Apr 19, 2020 | 08:38 PM
Otterby's Avatar
Otterby
That’s my plan if I can’t find the correct one
Old Apr 19, 2020 | 09:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford only sold the gasket with the antenna - B7C-18813-A .. there are 3 available NOS but I'd assume they'll be expensive.
Old Apr 21, 2020 | 12:15 AM
transam525's Avatar
transam525
I have a very nice antenna and pad available with only 4 years of road time/use before removal. The antenna was a NOS Ford unit I installed with the intention of adding the full OEM radio setup, however, I later decided to keep the truck 100% stock after adding/mounting the antenna. It still looks as good as the day I removed it from the original box back in 2007. Includes all components and cab mounting template (will only sell together with all components originally included in the assembly).
I also have the following for anyone interested:
-Used OEM radio (date stamped November 1959) with dash **** bezels and two new (reproduction) white *****. Unknown if operational.
-Original Ford factory radio repair manual (flawless)
-Used dash speaker grill
-Copies of OEM radio, speaker grill, and antenna mounting instructions/templates
PM if interested in any of these and I'll dig them out and take some pictures.
Josh Sipes
Sep 14, 2019 01:39 PM
alabamatoy
Aug 28, 2019 09:24 PM
Davgt500
6.7L Power Stroke Diesel
31
Nov 18, 2016 09:00 AM
KingBigJoe
20
Jun 12, 2012 06:05 PM
rcn
Jan 11, 2010 10:07 AM
