No lights
Old Apr 18, 2020 | 02:25 AM
jerryst's Avatar
jerryst
No lights
I just installed the ez wire 21 circuit harness in my 1955 ford f100. When I pulled the headlight switch I have no headlights or parking lights. I followed ez wire schematic. Also no lights for gauges or dashboard. Any ideas?
thanks
jerry
Old Apr 18, 2020 | 08:19 AM
DR Smith's Avatar
DR Smith
do you have power going to the switch ? do you have power to starter ? or is every thing dead
Old Apr 18, 2020 | 08:26 AM
schoo's Avatar
schoo
With 2 problems you maybe have a ground connection problem
Old Apr 18, 2020 | 12:19 PM
Mixer man's Avatar
Mixer man
Using stock headlight switch? Power to it?
Old Apr 18, 2020 | 01:52 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Not so stupid question, do you have ​​​​​power anywhere else? Did you hook up the battery?
Old Apr 18, 2020 | 02:51 PM
jerryst's Avatar
jerryst
yes truck started with no problems. The front parking lights worked when you pull the hazard plug on the side of the steering column. I still have to test the switch to see if it gets power. The headlights switch I didn't take apart yet. I will check today. check the easy fix stuff first.
Thanks
jerry
Old Apr 18, 2020 | 06:26 PM
56panelford's Avatar
56panelford
Did you install the breaker fuse for the headlights in the panel..?
Old Apr 18, 2020 | 10:16 PM
smallello's Avatar
smallello
Are we there yet?
I'm not sure, but isn't there a relay in the panel for the headlights? Is the relay in?
Old Apr 19, 2020 | 11:54 PM
jerryst's Avatar
jerryst
56panelford thanks for the information on breaker fuse. I saw this in the package with the ez wire. That’s the part about direction was weak. I placed the breaker fuse. Still the same. But I traced all connections to lights and found a bad connection. Now I have lights. The other problem is the dash lights on the headlights switch show no power. Any thoughts?
thanks
jerry
Old Apr 21, 2020 | 10:08 PM
jerryst's Avatar
jerryst
Update on no dashboard lights. after many attempts at getting the head light switch to work for the dashboard it worked. But the switch worked because the it was a bad connection you had to turn the headlight witch only a certain way to work. So I am buying a new switch so I can have dashboard lights.
Thanks
Jerry
Old Apr 22, 2020 | 12:55 PM
truckeemtnfords
Glad you got it figured out and thanks for the update. One of my vehicles has a touchy rheostat as well.
Old Apr 22, 2020 | 08:49 PM
abe's Avatar
abe
Those rheostats wear out.
RIKIL
Apr 18, 2014 10:30 AM
truckmonger1
1997 - 2003 F150
Feb 6, 2007 02:38 PM
rangershloman
Electrical Systems/Wiring
Sep 14, 2005 10:58 PM
wcmo sae
Jun 25, 2004 10:52 PM
gonefishin
Apr 2, 2003 11:02 AM
