Wiring woes!!!
Here's my dilemma: So far I've wired up the headlights, turn signal/parking lights, water temp, horn, etc...), but I am at a loss as to how to wire up the batt, alt, distributor. My battery is located on the passenger side of the engine bay against the firewall, I have the positive cable running to the remote starter solenoid (large post on left side) mounted on the firewall next to it, I have another wire running from the opposite large post running down to the starter. I have the ignition swith starter wire running to the small post marked with an "s". My alternator is a modern one wire, currently attached to nothing, likewise, there is nothing attached to my dist.
1. Am I on the right track so far?
2. How should I wire up my Distributor and alternator?
3. Should I run my wiring harness main pwr wire to the hot terminal on the solenoid or straight to the pos. post on the battery?
Thanks
By the way - great board! I'm on a few others for my other vehicle and they aren't nearly as informative as this one.
The distributor (points type?) is switching a ground to the coil (-) side, the coil (+) side has to come from the ignition switch. The run position to the coil (+) may have a resistor, bypassed in the start position.
The alternator will be feeding back to the solenoid hot terminal, but needs to go through the ammeter if you have one (series circuit). If you have a voltmeter, this runs in parallel (the alternator feeds directly to the hot terminal on the solenoid).
This is the basic electrics, and probably dated info, if you have more modern computer controlled stuff you need the correct wiring diagram. I offer it in hopes of helping you out, but you really should get a book on basic automotive wiring (Peterson used to have one), then you can be an expert! -I am not, I just have to keep my stuff running!
Good luck!
2: No fan of one wire alts. Bat terminal goes to Battery (thru amp gauge)
http://www.alternatorparts.com/what_...alternator.htm
Dist= points& condensor to - side of coil
+ side of coil to resistor
other side of resistor to ignition
resistor bybass for starting to + side of coil
Resistor may be built into harness (pink wire marked
do not cut or splice)
3: I think it would be better to attach it to the alternator Less messing around with battery terminalsand will make the gauge read right
The alternator power wire and the main pwr wire should meet at a junction block along with the amp. gauge wire. From the other side of the amp. gauge the wire goes to the starter sol. post where the pos. bat wire hooks. Best to use LARGE wire to connect the amp. gauge, it carries all the alt. output thru it on the way to the battery.
A proper size fusible link is best installed between the alt. wire and the junction block to protect the circuit, and between the junction block and the main pwr wire.
Let us know if the dizzy is points or electronic.
Between the advice all of you have been kind enough to provide, the tech articles, and the wiring schematic that came with the wiring kit, I think I'm on track.
I ran an 8 gauge wire from the "batt" terminal on my alternator to the hot side of my solenoid. So, the hot side of my starter solenoid currently has the battery positive cable, the wiring harness main power cable, and the alt "batt" cable. The opposite large post has a cable running to my starter, and the smaller "S" terminal has the starter wire from my ignition switch attached.
1. Anything wrong so far?
2. I purchased a new starter solenoid tonight (the one on the truck looks stock, if you know what I mean). According to the instructions that came with it, I am supposed to attached my coil wire to the "I" post, and then through the ballast resistor and then to the coil (sorry, the coil wire originates from my fuse block). Does this make sense? Can't I run the coil wire straight to the resistor and so on?
3. I have an aftermarket voltmeter (going in a custom gauge panel in place of original gauges). The manufacturer recommends wiring it into the fuse block (not really sure where to do that with this kit). Can I run the wire straight to the batt terminal on the alt, or will that drain the system?
4. There is a 2 pin connector in the engine block next to the oil filter (still unsure of the blocks year, any suggestions on how to determine that would be greatly appreciated). Could that be a connector for an electrical oil pressure gauge? If so, How can I go about wiring up a mechanical style oil pres gauge (also aftermarket).
I apologize for my ignorance, up 'til now, all I have dealt with is GTO's.
Thanks
1. So far, so good.
2> Didn't follow- someone else take a shot at it?
3. You want your voltmeter reading when you have the key on, not off -so find a "hot when key on" line to tie it to, the other side goes to ground.
4. You are looking for the oil galley fitting- should be some kind of sensor or switch screwed in there now. Unscrew it (motor off, obviously), and screw in one of the following - a tee fitting so you can run a switch for an oil light plus the pressure tap to the mechanical gage, the oil light switch alone, or the tap fittings for the mechanical gage. The other option, a sensor to run an electric pressure gage, is probably what you removed in the first place. The best, IMHO, is the light plus gage -the light gets your attention quicker than the gage, and if you loose oil pressure, you don't have much time to think about it.
Don't worry about being ignorant - we all are, just on differing subjects!
Thanks on the voltmeter confusion as well.William : It's the original points set-up. I purchased an Accell p/n:8140 "Super Stock" Universal 12V coil. It came with no literature, but since it does say 12 volt all over the packaging and the coil itself, is it a safe to say I should run the wire from the "I" post on my starter solenoid? If so, do I run the wire from my ignition switch (it's a pink wire marked "coil") to the "I" post and then to the coil, with no ballast resistor? Or do I run an un-reisited wire just from the "I" post to the coil as well as the wiring harness wire with a resistor inline?
Thanks , gotta run and get some work accomplished on it today (took 2 weeks of vacation just to get it running
