390 FE
Old Apr 14, 2020 | 08:03 PM
lincky92's Avatar
lincky92
390 FE
I got the 390 back from the shop and all seemed well again. Let me start by saying I am by no means an expert on motors, hence the stupid questions you’re about to get. I went to put valve covers on and there seems to be a decent gap between the intake and head causing the gasket to not seal properly. Is that a huge deal? And then we when finally got it in the truck we noticed the oil pan had a leak in the seal towards the back of the motor. Called the guy and asked what’s up, he said it’s from how the motor was titled when we brought it back and that it’s nothing to worry about. Is it? Thanks. I’ll have more im sure.
Old Apr 14, 2020 | 08:09 PM
ford390gashog's Avatar
ford390gashog
Well the intake is installed wrong first off. So when you omit the cork gaskets at the front and rear the manifold sinks. I am also going to bet the intake gaskets are so far off the intake runners are being blocked which will give intake runner turbulence on a performance build. We're the heads milled?
Old Apr 14, 2020 | 08:16 PM
85e150's Avatar
85e150
Also the oil pan should not leak regardless of engine orientation. How's it going to be when the oil is flying around in there like a couple of hoses spraying everywhere?
Frankly with errors like that I wouldn't trust anything the guy did.
Old Apr 15, 2020 | 07:23 AM
lincky92's Avatar
lincky92
How do you know the intake is installed wrong?
Old Apr 15, 2020 | 07:49 AM
Matt Bourgeois's Avatar
Matt Bourgeois
The intake is sitting to low, it is probably one or two things causing this, the sides of the intake were probably milled and possibly the intake sides of the head during this rebuild or previous rebuilds. Some milling is acceptable when material was removed from deck surface of block and bottom side of heads to get intake to fit properly, but in this case it looks like too much was removed. I'm not sure but someone may make a thicker intake manifold gasket set that might correct the problem, or you may have to find a different intake that has not been milled. Left as is you might get leaks or at the very least mismatched intake ports. The valve cover seal gap is too large although it rarely lines up perfectly it should be much closer.
Old Apr 15, 2020 | 08:22 AM
robertrpeak's Avatar
robertrpeak
From what I can see in your pic, you do not have the cork gasket under the intake, just goo. Cork would most likely raise it up to the correct height.
Old Apr 15, 2020 | 08:30 AM
baddad457's Avatar
baddad457
He needs the cork end gaskets and a thicker intake gasket. That's the thing about the FE's, the bolts have to stretch the intake towards the heads to seal properly, so the fit to start with is more critical.
As for the rear seal, I wonder if the builder even knew how to install the seals in the rear main cap. You have the crank seal and the two side seals and pins to install there
Old Apr 15, 2020 | 08:32 AM
lincky92's Avatar
lincky92
The confusing part is the driver side all seems to be at the correct height and works. The invoice claims he surfaced the heads, maybe just not the intake side. This whole truck has been a disaster from the start ha.
Old Apr 15, 2020 | 09:58 AM
trendyvan's Avatar
trendyvan
Looks to me that the block needed decked and paralled. If all these folks saying cork end gaskets would help are nuts if it binds that much you will crack the mainifold by warping it....wow
Old Apr 15, 2020 | 10:34 AM
robertrpeak
And you can see that from just one picture?
Pull the damn intake off, do it right and you'll be on your way.....
Old Apr 15, 2020 | 11:03 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
True, if you have a bad enough mismatch that you need the cork gaskets to make it line up again, well, the intake is just further up in the V which draws the intake further away from the heads.
Usually, you sit the intake in the valley with new gaskets, and it lines up. With or without cork end gaskets. If the geometry was done right by the machine shop
Once the heads and intake are milled, you don't use cork gaskets anymore, you use RTV ... for what I hope are obvious reasons
Old Apr 15, 2020 | 11:26 AM
baddad457's Avatar
baddad457
Probably surfaced just the deck sides. Most will not surface the intake sides unless instructed to. And then, that should only be done after bolting the heads on and verifying the fit first. How it fits with one block and heads may not be the same as on another.
Old Apr 15, 2020 | 11:27 AM
baddad457's Avatar
baddad457
We're all nuts ? Really ! I'm glad you're not working on my ****.
Old Apr 15, 2020 | 12:36 PM
'65Ford's Avatar
'65Ford
Aftermarket intakes often need a little fitting, especially on 50+ year old block/head combinations that may have been milled. While it's preferable to have the intake to head interface line up perfectly flat, it's okay if it doesn't. Many guys use silicone combined with cork gaskets to seal the valve cover gasket due to the narrow sealing surface and having only 5 bolts to tighten the valve cover. Even if the intake and head matched perfectly you'd want to add a dab of silicone at the interface. Your situation will leak as is but will be okay with strategically applied silicone.
Very, very few people ever use cork on the china walls for any reason today...most guys throw them away and only use silicone. You can get thicker intake gaskets but I'd leave your intake alone until you see it leaking (outside or inside). If the engine is completely installed, you might pressure check the radiator to see if the intake leaks any coolant before starting the engine. Definitely don't use cork gaskets on the china walls and just tighten it down. That might result in a cracked intake but it will definitely suck oil and probably air along with coolant. Consider thicker intake gaskets but verify they match your ports.
Oil pan should seal...kinda weird if it's leaking. Verify where the leak originates because all engine oil leaks end up on the oil pan (e.g. fuel pump, timing cover, intake, etc)
jakeharp
Oct 13, 2016 06:24 PM
alchemist1
18
Oct 16, 2014 06:23 PM
Crumm
21
Feb 27, 2005 10:18 PM
billdevaul
Jul 12, 2004 08:41 PM
yukonhighboy
Mar 16, 2004 07:53 PM
