dual exhaust
Old Oct 15, 2003 | 08:21 PM
jesse460's Avatar
jesse460
dual exhaust
when running dual exhaust do i need to put a crossover to mount the o2 sensor or can it be in just the pass. side pipe
Old Oct 16, 2003 | 08:47 PM
jesse460's Avatar
jesse460
i guess nobody knows
Old Oct 16, 2003 | 10:13 PM
lexluthr69's Avatar
lexluthr69
I've got mine mounted in the passenger side pipe 4 inches behind the collector of my long tube headers. It's normally a better idea to TRY to get it to read both sides of the exhaust so it you will have a better idea of how the overall engine is running vs just the one side. However, this makes it hard. I had a dual in/out hi flow cat installed, and have the bung for the sensor on it, but it's mounted a slight bit too far, and doesn't register hot enough for the sensor to be accurate.
So.... yes you CAN just put it in one pipe and run.
Good luck
Luke
Old Oct 17, 2003 | 11:13 AM
MustangGT221's Avatar
MustangGT221
The stocker just had a small pipe going between the two pipes with the sensor in it, you should have it read both sides.
Old Oct 17, 2003 | 02:26 PM
Hit Man X's Avatar
Hit Man X
I have it in my passanger side header collector...I'll try to post up a pic here.
Old Oct 17, 2003 | 02:30 PM
Hit Man X's Avatar
Hit Man X
[IMG]https://www.ford-trucks.com/user_gallery/displayimage.php?
&photoid=17939&width=0[/IMG]
OR
https://www.ford-trucks.com/user_gal...=17939&width=0
Old Oct 17, 2003 | 02:36 PM
dwnett's Avatar
dwnett
A friend of mine who owns a muffler shop told me I would need to put a crossover and install the sensor in it. 89 f150 5.0
Old Oct 17, 2003 | 09:55 PM
cruehed1's Avatar
cruehed1
I have an 89 F150 w/ the 5.0 and when I had my dual exhaust installed w/ headers I had to put an H-pipe in to satisfy the O2 sensor..... up until I had the H-pipe put in the Check Engine light kept coming on and the truck ran like crap..... afterwards, no light and runs great! Hope this helps.
Jayson
Old Oct 18, 2003 | 12:35 PM
jesse460's Avatar
jesse460
seems everyone has a different opinion i think i wll just put it in the passenger side for now and see if it works my check engine light is on all the time anyways since i removed the egr.
