2019 F350 dually and air springs
I have a 2019 F350 dually. GCWR 14,000. I will be towing a 43 ft. 5th weighing between 22,000 to 24,000. The pin weight is between 4800 and 5300 lbs. My question is would air bags improve the ride working in conjunction with the truck springs or do you feel it is a waste of money and time? Please only persons owning a dually respond. If you don't have or haven't previously had a dually your answers are totally worthless to me.
Thank you,
Rod
Thank you,
Rod
I have had them on every truck I owned for the last 40 + years. If you can the wireless or in cab controls are worth it as you can set the empty and loaded pressure so its quick and easy to inflate and deflate as needed and you can adjust the pressure as you drive to find the ideal pressure for you set up
