F150 STX with 3.5 Eco vs F-250
never mind. Wrong one. Hang on...here it is https://www.koonsfordbaltimore.com/n...bd15e66e39.htm
Max tow package. Has the mirrors too...has the 20 inch rims as well.
That's covered with this one...what do you think of this? Can you look at it and tell me what you think please?
That’s a rare truck. I’m surprised to see an STX equipped that way. Most are pretty basic.
https://www.windowsticker.forddirect...b-a240688a3b0e
I've towed quite a bit over the years of my F150s, and this was probably the heaviest one. Total weight was around 12,000 pounds, and the truck did a great job with it. I had the 3.5 L EcoBoost with the max tow package and 3.73 years, and it had far more power than it needed. If loaded and set up correctly control and sway shouldn't be a problem, but I wouldn't go much heavier than this.
For occasional use pulling 10K+, I think the F150 makes the most sense. A lot more livable as a daily driver, too.
If that advertised price is correct that's nearly 10k off. In my area that would be a deal as the XL/STXs don't seem to get the same discounts or incentives XLTs do. Just my 2 cents anyway.
Could try making them an offer and see if they'll jump to move stock given the current state of auto sales.
I have a 18 F250 4x4 6.2 3.73 truck and a 19 F150 4x2 2.7 3.55 truck. IMO, the 2.7 is a way better towing engine. Towing the same trailers, I much prefer towing with the 2.7, so I'm sure you would be pleased with the 3.5. It seems the f250 is good until highway speeds where wind resistance plays more of a part the weight, and the 6.2 has nothing unless your up a 4k rpms. I just hate that I have to be in 4th gear towing a small load on flat highway. I pretty much never drive the f250 anymore, because I prefer the F150 so much more.
But power to weight alone means the 2.7 L EB will feel like a racecar compared to a 6.2 L super duty. And the turbo diesel like torque curve makes for an awesome towing experience.
#29
So it has to be a crew cab? Forgive my ignorance, but which model has the 157" wb? I was looking at this one but it only has 145" WB https://www.koonsfordbaltimore.com/n...7883136f0a.htm
#30
