MSD 5 or 6A?
Old Feb 12, 2001 | 03:22 PM
bjoern's Avatar
bjoern
MSD 5 or 6A?
I want to upgrade the ignition of my 1988 F150 302 5.0l to an MSD multi-spark ignition. Do I need the MSD 5 (inductive discharge) or the MSD 6A(capacitive discharge)? I already have the Accel super coil and 300 8.8mm wires.
Old Feb 12, 2001 | 03:31 PM
cgl's Avatar
cgl
MSD 5 or 6A?
I believe you need the 6 series. I run the 6AL on my 90 F-150.
Old Feb 12, 2001 | 03:36 PM
bjoern's Avatar
bjoern
MSD 5 or 6A?
allright, good. I checked back on the Accel coil and the catalogue said it was capacitive. That means the 6A is the one to go. Thanks!
Old Feb 12, 2001 | 10:23 PM
jbhf250's Avatar
jbhf250
MSD 5 or 6A?
I have the MSD 6AL with the accell super coil.
Worth every penny!!
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Feb 15, 2001 | 12:19 AM
ajstephan's Avatar
ajstephan
MSD 5 or 6A?
I'm just started towing a boat in my '95 F150 4x4 (300/Mazda5/3.55s). With the canvas up, it's over 8ft tall and limits me to ~60mph on the highway. Would a MSD 6A help on the top end?
Old Feb 16, 2001 | 12:55 AM
knuckles's Avatar
knuckles
MSD 5 or 6A?
The MSD 6A is a great piece, but it won't help you too much with your boat towing problem. You either need deeper gears (higher numeric ratio) or MORE POWER. The MSD unit may give you a little bit more power, but not enough to overcome the brick you're towing.
If you're feeling rich, check out U.S. Gear's underdrive/overdrive unit. About $2k USD installed. Not cheap, but highly effective.
Old Feb 16, 2001 | 01:00 AM
xaviar's Avatar
xaviar
MSD 5 or 6A?
Has anyone experienced any hard starting issues after installing a 5A or 6A MSD box. This only occurs on the first start of the day after sitting all night. It seems to have to crank longer to start but after it starts runs like a charm.
My installed features are listed below.
Any info would be greatly appreciated
Xaviar
96 F-250HD 4x4 460/E4OD 4.10
Banks Power Pack, MSD 6A
MSD 8227 Coil, MSD 32199 8.5 Wires
Old Feb 16, 2001 | 08:32 AM
chefbill's Avatar
chefbill
MSD 5 or 6A?
