Steering arms interchangeable ???
Old Apr 7, 2020 | 09:30 PM
hentzrd's Avatar
hentzrd
F100 1976 4WD / 1978 F150 4WD
Folks
I was told that you can interchange the 1976 F100 4WD steering arms and upgrade them to the 1978-79 4WD type. Has anyone ever completed this task is it even doable?
Thanks
Randy
Old Apr 7, 2020 | 11:01 PM
broktruk's Avatar
broktruk
My 76 4x4 SWB. I upgraded to 79 tie rods. Much better feel, esp with 4” lift. No mods needed.
Old Apr 8, 2020 | 08:29 AM
hentzrd's Avatar
hentzrd
Thanks. I am planing on doing that now that i know it works!!!
Randy
Old Apr 8, 2020 | 08:38 AM
68Flareside240's Avatar
68Flareside240
From my understanding you change the pitman arm to the 78-79, then use centerlink, draglink, and tie rod end for 78-79. Correct me if I am wrong but I believe the older parts are obsolete because the 78-79 is a better design and an upgrade.
Old Apr 8, 2020 | 08:40 AM
hentzrd's Avatar
hentzrd
Thanks I think my Pitman arm ie the same but I have the 78 if I need it.
Old Apr 8, 2020 | 08:41 AM
hentzrd's Avatar
hentzrd
Did you have to modify the steering shock???
Old Apr 8, 2020 | 03:00 PM
broktruk's Avatar
broktruk
I didn’t. Don’t think you would have to either. If you have the ability to get the pieces do it, it is a worthwhile upgrade.
I do believe the pitman arms are different. I put in a drop pitman since I was there.
Ford1959F100
Jul 15, 2019 07:23 PM
leonharu
Jun 22, 2018 10:50 PM
TheGermanGuy
21
Nov 26, 2016 07:30 AM
brenjimin
13
Jul 27, 2012 09:30 PM
racer2012
Jan 6, 2012 05:51 PM
