460 Performance Cylinder heads
Old Apr 1, 2020 | 10:59 PM
wlk1020's Avatar
wlk1020
I'm looking for info on performance cylinder heads for my 85 F350. I built my motor years ago with many more but I'm ready for cylinder heads. I'd prefer cast iron for durability. Any info on products,builders,etc be helpful.
Old Apr 1, 2020 | 11:04 PM
85e150's Avatar
85e150
Define "performance". Early iron heads work well, some later heads can work.
Kelly hotrod - Ford Engines Page 3
Old Apr 1, 2020 | 11:22 PM
wlk1020's Avatar
wlk1020
Aftermarket heads that fixed some of factory flaws like the choked exhaust runners etc. Better flow etc
Old Apr 1, 2020 | 11:26 PM
85e150's Avatar
85e150
Post 10 lists in one feller's opinion.
https://www.460ford.com/threads/best...-heads.143711/
A cookbook if you are building an engine:
https://www.460ford.com/threads/460-...-24-09.119213/
Old Apr 1, 2020 | 11:45 PM
matthewq4b's Avatar
matthewq4b
Aftermarket cast iron heads are available for the 460 but NONE of them are cheap. Acquiring and getting a set of factory C8 C9 D0VE heads ported would be cheaper.
And really unless you going circle track racing or building for a jet boat or some other extreme severe service application, the aftermarket AL heads will do you just fine.
Old Apr 1, 2020 | 11:59 PM
wlk1020's Avatar
wlk1020
Excellent. I liked the break down of the different heads. I'll look into what heads I got on her. I'm presently running 30-40 over can't remember. Hypereutectic pistons. Block decked heads shaved to true 9.0 compression. Complete comp cams k kit for all torque set up. Edelbrock intake Holley 750 carb. Tuned with afr meter. Took 20 +hrs on that as I drilled and customized air bleeds jets power valve ports etc. Long tube headers. Msd mechanical advance distributor with 6al box. I'm getting ready to install an old Holley commander 950 on it to control timing which will give massive torque change etc. That build is ten years old and several thousand hard miles. Runs like a top and will slip the stock ZF 5 speed clutch. Just wanted to finish it off with better breathing
Old Apr 2, 2020 | 04:01 AM
Rembrant's Avatar
Rembrant
Talk to Scotty at Parkland Performance. He's a 460 builder and sells heads and top-end kits.
Parkland Performance Auto Machine - Home
I've dealt with him a couple times and he was very helpful. I just emailed him a few days about about a 460 EFI in a vehicle I just purchased.
brocluno
WTB - Parts & other
Sep 23, 2015 12:26 PM
HD991994F150
May 15, 2013 10:44 PM
smokersteve
Sep 9, 2012 08:06 AM
