drum bolt patterns
Old Apr 1, 2020 | 07:18 PM
greyhound's Avatar
greyhound
drum bolt patterns
Hello, Would like to know how many drum bolt patterns they had in 1960? You had the F 250 truck with 8 bolt pattern. Then the F 100 with the five bolt pattern. Not worried about the bigger trucks and up. My question is that I was watching Full Custom Garage and he was building a rod. He was in a junkyard and was pulling a front axle from a 1960 ford panel with a single window on each side of the panel. This axle had a 6 lug bolt pattern. Was this a Marmon Herrington truck since it had this bolt pattern? Also seen on pinterest a 1960 panel truck with two windows on each side. It was a old ambulance , was this a Marmon Herrington unit also ? Thanks for the info , just for the knowledge.
Old Apr 1, 2020 | 07:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Was this a Marmon Herrington truck since it had this bolt pattern? Also seen on pinterest a 1960 panel truck with two windows on each side. It was a old ambulance , was this a Marmon Herrington unit also?
No F100 or F250 of any year had 6 lug wheels.
Marmon-Herrington of Indianapolis IN converted trucks to 4WD // FoMoCo introduced factory installed 4WD in 1959 F100/250.
Panel trucks were converted to ambulances by aftermarket body companies.
Old Apr 1, 2020 | 07:50 PM
greyhound's Avatar
greyhound
Ok , Thank you again NumberDummy. I thought I new that but was puzzled anyhow. My norm.
Old Apr 1, 2020 | 09:18 PM
JohnNewb's Avatar
JohnNewb
Maybe p350? F350 had six lug.
Old Apr 1, 2020 | 10:15 PM
NumberDummy
Originally Posted by JohnNewb
Maybe P350? F350 had six lug.
P350 (P series Parcel Delivery) could have 6 lug wheels (same as 1953/66 F350) or 8 lug wheels.
Old Apr 2, 2020 | 04:08 AM
greyhound's Avatar
greyhound
lug bolt pattern
Good Morning,
NumberDummy I will see if I can find a reair of the show and take a picture of the panel and post it here.
Old Apr 2, 2020 | 04:41 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Mid year Marmon-Herrington F-250s have 6 x 7.25” pattern hubs and wheels. But not on an F-100 panel truck. Stu
Kirk-NJ
Feb 23, 2020 02:43 AM
longview1
6.4L Power Stroke Diesel
Nov 16, 2010 12:25 AM
Fordnite302
Mar 10, 2003 05:45 PM
chulsey12
Nov 26, 2002 06:34 PM
tlak
Mar 9, 2001 10:36 AM
