Check engine light / skips some times engine stops
Old Mar 29, 2020 | 04:30 PM
Roberto Valadez's Avatar
Roberto Valadez
I have a 2000 F250 with about 260,000 miles on it. Been great but lately the check engine light is on after I start it for about 1 minute and the idle and power is low. Then the light goes out and it revs up and idles normally. Sometimes when I drive it, it will sputter / loose power for a split second then its fine. Then I have had it just shut off completely then I put it in neutral and start it up and continue to drive. I have read ICP sensor should be changed out but any other suggestions would be appreciated if anyone else has had this issue. Thanks!
ugh3012
May 23, 2016 09:14 PM
Joehurd
6.4L Power Stroke Diesel
Jan 11, 2016 09:03 AM
chrisginco
Apr 25, 2013 04:36 AM
new2ranger
1983 - 2012 Ranger & B-Series
Jun 9, 2003 01:44 PM
