cold start problem
Old Oct 15, 2003 | 11:55 AM
Jack 357's Avatar
Jack 357
cold start problem
I have an 86 F150 with a fuel injected 302. On a cold start it fires off ok but will not go up to a high idle . It just dies unless i give it gas. Ater it warm up it idles fine.
Old Oct 16, 2003 | 08:08 AM
locknkey's Avatar
locknkey
Someone adjusted the idle stop screw? - your not supposed to do that....
Old Oct 16, 2003 | 08:09 AM
locknkey's Avatar
locknkey
The TPS could be not working.
Old Oct 16, 2003 | 08:10 AM
locknkey's Avatar
locknkey
Throttle position Sensor
Old Oct 16, 2003 | 07:46 PM
Jack 357's Avatar
Jack 357
I am going to check the TPS tomarrow and the idle stop screw has not been adjusted. Also have allready changed out the coolent temp sensor and cleaned the air bypass valve.
Old Oct 28, 2003 | 08:41 AM
Seeker's Avatar
Seeker
Jack, I'm having the same problem, If you find a solution please post it.However I'am getting a code 67(pull your codes c what you get)
Old Oct 28, 2003 | 08:10 PM
Jack 357's Avatar
Jack 357
Found the problem
I tested the MAP sensor and found it was out of range, not by much but enough to make it not to run when it was a cold start.
All is well with a truck that has 164,000 miles on it and still going.
Old Sep 20, 2004 | 11:45 PM
g0ldrush's Avatar
g0ldrush
your problem could be the air injector bypass valve
http://www.rockauto.com/ref/Motorcra...ml?cx-1522.gif
http://www.rockauto.com/ref/Motorcra...tml?cx-560.gif
