dump piston replace/rebuild
Old Mar 25, 2020 | 06:19 PM
billybe4od's Avatar
billybe4od
removed the leaking piston from my dump pickup leaking bad a new venco piston bout 600.00 to the door going to check on a rebuild it was a job an a half !!!!!
Old Mar 25, 2020 | 06:31 PM
1TonBasecamp's Avatar
1TonBasecamp
Big mess!
Was it still working at all? Or was it DOA at that point?
Paul
Old Mar 25, 2020 | 11:42 PM
TobyB's Avatar
TobyB
I have had very good luck resealing hydraulic cylinders IF I can get them apart. the 4' Harbor Freight pipe wrench helps...
...and way more heat than I would think prudent.
Then seals and packings from places like Hercules, you just order by diameter and dimensions. It's the only way to keep
older farm equipment sealed up, as the cylinders are long- discontinued. And the new seals come in much improved materials.
what I've found,
t
Old Mar 26, 2020 | 08:25 AM
billybe4od's Avatar
billybe4od
The piston was pisssing out the ram seal was able to raise it a couple feet but enough to work on it That bed is heavy !!!
i can get the seal kit 137.00 but probably half to have it done But cheaper than a new piston
MichiganLarry
38
Jan 28, 2018 05:44 PM
66with352
39
Nov 7, 2012 06:45 PM
Pablo-UA
Aerostar
Jul 20, 2009 12:34 AM
Aussie F350
Jun 15, 2008 08:52 PM
alabamabuddog
Aug 25, 2003 10:58 PM
