no tachometer
Old Jan 29, 2001 | 01:50 PM
marnold's Avatar
marnold
no tachometer
Thanks to everyone who replied to my post. This is a good message board. I'm looking for a tach cluster at the local salvage yards. I hope that the swap is a no-brainer, difficulty wise.
Old Jan 30, 2001 | 08:43 AM
TallPaul's Avatar
TallPaul
no tachometer
marnol: If your truck is like the '95s and you don't have electronic 4wd controls you can put the dash in the right of the dash by cutting a hole. I fit a large tach, probably 3" wide in mine. This one is held in merely by the tightness of the opening:
https://www.ford-trucks.com/dcforum/User_files/3a55d02e3ce54623.jpg
Old Jan 30, 2001 | 10:39 AM
daywalker's Avatar
daywalker
no tachometer
Thats where I put mine.
Daywalker
92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed
http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high
Old Jan 30, 2001 | 10:52 AM
bgodkin's Avatar
bgodkin
no tachometer
Hey Hotrod88,
My truck was doing that for a while and I changed the voltage regulator. Problem solved. Also my batteries charge better than they did now.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Jan 30, 2001 | 04:09 PM
Pastmaster's Avatar
Pastmaster
no tachometer
>my post. This is a
basically it's just a unplug, and replug. If you want to keep the same mileage, youll have to unplug the memory bank. And swap. Also, if you intend to trade this truck down the road, keep onto the old cluster, and swap them back out. You can sell the cluster later if need be. My 1993 had the tach originally. If I ever sell it, I'll do the swap too.
Old Feb 3, 2001 | 01:55 AM
charlez's Avatar
charlez
no tachometer
Could someone please post a pic of a dash cluster with the factory tach? (92-96) I can't recall what they look like.
Old Feb 7, 2001 | 02:37 AM
hotrodford_88's Avatar
hotrodford_88
no tachometer
Unfortunately my truck has the regulator built into the alternator. So I really can't change it out. It has a new alternator in it. Thanks for the tip though. It might work on my 65 eventually.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Feb 20, 2001 | 05:52 PM
cheshireccat's Avatar
cheshireccat
no tachometer
where is the tach wire located, I'm trying to install a shift light, it has a positive, negative and a wire for the tach wire to connect to, where can I find that wire on a 95 explorer sport?
Old Feb 20, 2001 | 06:07 PM
KevinT's Avatar
KevinT
no tachometer
It's one of the leads off the coil, there's only 2 so try both, for me its the left wire on the plug.
1995 F-150XL SC/SB
http://members.sounddomain.com/blind
5-Star Rated F-150 (Big Stereo)
Old Feb 20, 2001 | 07:29 PM
KevinT's Avatar
KevinT
no tachometer
