73 f250
Old Mar 21, 2020 | 08:46 AM
Oldschool73f250's Avatar
Oldschool73f250
73 f250
I just bought this truck for a farm truck. It hasnt been used for a couple years. Had 2 tanks. Vin shows a 6cyl but had an 8cyl in it. I have done some research on getting it running. Emptying gas tanks. Change fluids. Needs steering box. No brakes. All easy fixes. If the motor is seized, what can I do to free it? Thanks
Old Mar 21, 2020 | 09:06 AM
alans77crew's Avatar
alans77crew
I watched my dad do this about thirty years ago! he pulled all the plugs and squirted atf in each cylinder and let it set for a few days and then tried turning it back and forth a little at a time. But he never even tried to turn it with the starter till he confirmed it was loose and could turn a full revolution.
Old Mar 21, 2020 | 09:16 AM
1978F100Custom's Avatar
1978F100Custom
I've used Marvel Mystery Oil before. Remove all the plugs, pour in the oil, be patient, and it will break loose. I've heard alot of success stories with ATF, and regular motor oil as well. The key is to be patient...you have to let it weep through.
Old Apr 26, 2020 | 02:08 PM
Oldschool73f250
73 f250
Well I put Diesel and atf down the carb and in the plug holes. Let it set, was able to turn the motor. Changed oil and it did work. Started right up after a linkage adjustment.
RangXLT
15
Nov 29, 2017 10:22 AM
jwtimme
24
Jun 25, 2011 12:37 PM
78fordman
Jan 14, 2004 09:42 PM
