Wiper relays?
Old Mar 20, 2020 | 11:52 AM
danparks's Avatar
danparks
Wiper relays?
Hello everyone. New to the forums. Have a 2006 F-150. Hope you all can help. Haven't been able to find information elsewhere. Wipers were working fine on intermittent just fine. Then, all of a sudden, started swiping normally as in the "on" position. Parked the vehicle a short time later, turned the wipers "off" but they kept swiping. Shut the truck off and removed the key and the wipers kept swiping. The ONLY way to get them to stop was by pulling the fuse. I just replaced the turn signal switch on the steering column hoping that would fix the problem but it didn't. (I was have a problem with the turn signals that was coming from that switch so thought the problem was now affecting wipers also) I assume the problem is now in a relay but I can't find where the relay(s) are for the wipers. Can someone point me to them or if the solution is elsewhere, please help. Thanks.
Old Mar 20, 2020 | 12:47 PM
projectSHO89's Avatar
projectSHO89
All the control electronics are built into the wiper motor module. No discrete components external to it except the fuses and the MFS. The MFS simply has inputs that tell the control electronics inside the motor module what the driver wants.
The solution, unless you want to tear into the module and try to repair it, would be to replace the module.
Old Mar 20, 2020 | 12:48 PM
danparks's Avatar
danparks
Where is that located?
Old Mar 20, 2020 | 12:56 PM
projectSHO89
Under the trim/cowling at the base of the windshield.
It's also posible that a short-to-ground in the wiring from the MFS (or a defective MFS) could cause your specific symptom. Do the wipers run at low or high speed? Does the intermittent feature work or not?
Old Mar 20, 2020 | 12:58 PM
danparks's Avatar
danparks
They run at low and high. No Intermittent and no "off". Thanks. I'll pull the cowling this weekend and look for it.
tm01027
Sep 11, 2017 02:57 PM
Victory13
Modular V8 (4.6L, 5.4L)
Feb 8, 2017 05:28 PM
Monzter Kuztomz
Jul 18, 2011 11:18 AM
roachslayer
Jul 4, 2010 07:39 PM
reddogracing
May 27, 2009 11:33 PM
