Sponsored by: Real Truck
Where is 4x4 Auto?
Old Mar 20, 2020 | 09:18 AM
WWR's Avatar
WWR
Originally Posted by willieb1172
He was asking about 4x4 auto not all wheel drive. 2 totally different drive types. 4x4 auto is 2wd with on-demand 4wd when rear wheel slippage is detected..
Actually, it's semantics. "All wheel drive" is a term that can legitimately mean a lot of things.
To me, AWD is anything that can choose when to power which wheels, OR full-time but with a center diff like an NP203. And as stated by AK4X4, the new systems can choose how much and for how long to engage the front output - they lever a fork internally that mashes (auto trans) clutch packs together, but depending upon what the WSS's, tone rings, VSS, TPS (and probably other stuff) are telling it, it can engage the front with very little bias or a lot of bias, for as long as it chooses.
It also doesn't have to be rear drive/front on demand ....Quattros of old were front drive and could send a little (maybe up to 40%?) to the rear if needed. I honestly don't know how Subaru handled it when they went "auto" (and I don't care)
Anyway we can all believe what we choose, but AWD can mean a lot of things, and none of them are wrong.
Old Mar 20, 2020 | 09:38 AM
Desert Don's Avatar
Desert Don
Stick around long enough and the SD will be all electric with an electric motor on each wheel; thereby the PCM will tell each wheel when and how hard to pull.
Problem solved.
Driver now will not have to think at all!!!!
Old Mar 20, 2020 | 09:52 AM
WWR's Avatar
WWR
Problem solved.
This is absolutely true, but they'll build a heavy duty AWD 'case first. I bet at least once a month Ford sees an attempted warranty claim for driving cross country in 4hi
Auto headlights, auto wipers, back-up cameras, collision avoidance and on and on. Hell even the old 2-tank fuel systems were deleted 'cause we can't expect the consumer to flip a switch to change tanks....there's no question Ford will try for AWD in the SuperDutys soon....I'd avoid the first couple model years of THAT - sounds like the latest assignment for the few gray hair engineers still employed from Team TFI and Team TTB!! They just finished botching the new Explorer so they need the next project...
Old Mar 20, 2020 | 03:57 PM
willieb1172's Avatar
willieb1172
I was speaking specifically about what Ford calls their different systems and what they mean. But from the perspective of all manufacturers I don't disagree with your statements, because as the technology in these systems increase, the functionality of different 4x4 systems overlap and function differently even though sometimes they are called the same thing. But before all this technology happened, traditionally AWD meant a non-selective all time 4wd with a center diff.
vespaholic
General Automotive Discussion
Feb 5, 2020 06:31 PM
vespaholic
Arkansas Chapter
Jan 27, 2020 10:13 AM
rotun
Offroad & 4x4
Mar 2, 2010 12:22 AM
80351
Maryland Chapter
287
Oct 1, 2008 06:28 AM
j&bsuv
Missouri Chapter
Jun 25, 2006 07:33 PM
