Which starter button
Old Mar 16, 2020 | 06:34 PM
ynot321AB1's Avatar
ynot321AB1
One place I read that if you switch from 6V Positive ground to 12V Negative ground you cannot use the regular starter switch and have to go to one with 2 poles. Another place says it is OK to use the standard starter button with 12V and negative ground. Which is correct???
Old Mar 16, 2020 | 07:05 PM
49fordv8f4's Avatar
49fordv8f4
You can use the original starter button with 12V. You can also use the original 6V starter and start solenoid.
Old Mar 16, 2020 | 08:40 PM
Mixer man's Avatar
Mixer man
It depends on if you replace the starter relay with a different type. If you switch to 12 volt negative ground and don't replace the starter relay, you don't have to touch anything. The switch, relay, and starter motor will work just fine. You got some misleading info.
Old Mar 16, 2020 | 10:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1952/55 starter switch button (2C-11500-A) was also used as the windshield washer push button switch on 1965/66 F100/250.
It was located above the ignition switch on the left side of the dash.
hamptonsgarage
33
Feb 2, 2020 09:59 PM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
chappys4life
Jun 29, 2012 12:05 AM
Surf Daddy
Jan 10, 2009 08:27 PM
drhist00
Oct 31, 2001 02:46 PM
