Sponsored by: Real Truck
Bilstein Shock Absorber
Old Oct 14, 2003 | 10:52 PM
BigDawg54's Avatar
BigDawg54
i know the suspension is supposed to be stiff on trucks, the super duty in particular. but i was wondering if Bilstein shocks would help smooth out my ride without sacrificing a good solid suspension that can handle anything. i have heard that the Bilsteins are the way to go and seem like a very dependable long lasting shock. Would the Bilstein 5100 series shock fit under the Super Duty or would i have to go with the lower series shocks? If you have any other suggestions on a brand let me know.
-bigdawg
'03 FX4 F250SD SC Long Bed 5.4L
Old Oct 15, 2003 | 08:16 AM
FortyFords's Avatar
FortyFords
Yes ,I believe that is the shock of choice !
I don't have them but ,wev'e talked about them here alot .
Someone with them will be along!
Rich
Old Oct 15, 2003 | 01:02 PM
ktm520mxc's Avatar
ktm520mxc
Shocks
I put bilsteins on my 2000 F 350 V 10 and noticed a difference in the ride. The wife even commented that the truck seemed to have a smoother ride. She didn't know that I had changed shocks.
The shocks are rated for the F350 so they will take a load.
Old Oct 15, 2003 | 04:19 PM
BigDawg54's Avatar
BigDawg54
hey there ktm520mxc, you are referring to the 5100 series shocks correct? thanks for the help i appreciate it.
-bigdawg
Old Oct 15, 2003 | 07:39 PM
02superstroker's Avatar
02superstroker
thats what i got, the 5100 series.. im never going back!!!!
They are great riding and look great too!
Old Oct 16, 2003 | 08:00 AM
nitwit29's Avatar
nitwit29
But, don't you have to have a lift of at least 3" to get the 5100's? I got an add-a-leaf in the front which raised it about 2" and I also have 4" blocks in the rear. Even with this set-up I am sure I can't get the 5100's. Anyone have this problem?
1999 F-350 4x4 PSD SRW
Old Oct 16, 2003 | 10:45 AM
RedCrewCab4x4's Avatar
RedCrewCab4x4
Question
5100's are on my shopping list also, even though I don't have any lift (yet). Planning on a 2" leveling like Nitwit29. I read earlier that there are different applications and stock numbers for 5100's depending on your setup, correct? Anyone?
Nitwit29, which kit did you go with and how do you like it? Is your nose still slightly lower than the tail? That's what I'm after.
RedCrewCab4x4
Old Oct 16, 2003 | 06:40 PM
DCSpecial's Avatar
DCSpecial
You can get the Bilstein 5100s for a stock truck.....the shock part number is for 0-2" of lift if I remember correctly.....but they are only available in the yellow body/blue boots.......if you go 3" or more you can get the zinc body/black boots 5100s.
0-2" lift 5100 w/ SD specific valving part #:
front: BE5-2818-HO
rear: BE5-2819-HO
Hope this helps.
Old Oct 16, 2003 | 11:22 PM
tankhead's Avatar
tankhead
Are the 2818 and 2819 valved for the SD? I thought I read somewhere that only the 3-6" of lift are 5100's valved for our truck. I think I remeber where i can find it.
I tried this search and found this post by OverKill. But I remeber reading it again here recently cause this was posted in August.
LINK .
Keep searching for the more recent post cause as I remeber the 2818 and 19's were pointed out directly as not being valved for the SD. Kinda bugs me DCSpecial cause it just doesn't sound right.
Looks like you are right. LINK
