Sponsored by: Real Truck
Fuel gauge from Hell
Old Mar 15, 2020 | 05:03 PM
A-Aron9's Avatar
A-Aron9
If any of you folks know of a thread already addressing this please point me in that direction, I wasn't able to find much.
I have an 08 F350 6.4, my fuel gauge took a dump on me a couple weeks ago. It would be buried on E with the low fuel light on and stating my range to E was 0 mi. Once I got below about a half tank it would read accurately(ish) about 75% of the time. It seemed like the colder the weather, the less likely it was that the gauge would show anything other than E.
I finally built up the courage to drop the tank and put a new sending unit in, 4 hours and $300 later, brand new Ford sending unit in the tank and the gauge still reads empty. On my 7 mile drive back from my buddy's shop the gauge started working accurately. I even stopped and filled the pickup to verify and it read full. The next morning I jumped into the pickup and the gauge is buried on E again.
I haven't had a chance to put the multimeter on the old gauge to see what the resistance numbers are, it could be that the old sending unit was still good. I'm thinking either wiring issue/short or my gauge cluster is on the way out?
Any ideas or experience with similar symptoms would be appreciated. I love this old pickup and I love not having a car payment, but as she ages she is getting harder to love all the time. I guess that is the case with everything that has a motor.
Old Mar 16, 2020 | 05:51 AM
RustyXJ's Avatar
RustyXJ
Do you have a Bluetooth obd II adapter? If so, torque pro apk is $5, load the custom Ford PIDs, and you can check what the pcm is down reading for fuel. If the pcm is all over, it's a wiring issue. If the computer is fine, cluster issue.
Old Mar 16, 2020 | 06:53 AM
Djosbun's Avatar
Djosbun
Check for corrosion or poor pin fitment at the fuel pump harness connector. Follow the harness towards the front of the truck, looking for any wire damage. Also check any other harness connectors along the route.
-- Dave
eric8
Feb 17, 2019 03:33 PM
WGS
Jan 31, 2014 08:02 AM
somehowford
Jan 13, 2013 12:29 AM
ccbrett
1978 - 1996 Big Bronco
Nov 23, 2011 02:37 PM
Slag-hammer
16
Dec 13, 2006 11:27 PM
